a brief summary of our topology:
1x MSM710 Controller
6x MSM422 Access Point
1x PoE Switch
the APs route through the PoE switch, to the controller LAN port. the controller Internet Port then routes to our TMG server.
Controller is being used for authentication and access control, using the default VSC. WPA2 Wireless protection is the only authentication currently enabled. Controller is also being used for DHCP
The problem is anything connected to this network via Wi-Fi is basically unable to access any web pages. Google will load, i guess becuase its relatively small, but anything further (including actually using google to do a search) just doesnt load. pages frequently time out or only half download.
the only thing i have noticed that might be a clue, is that on the Status > Ports page, the 'controller data tunnel' transmit is getting a few hundred errors per hour. I cant however find any clue as to what this might mean.
currently there are no more than 30-40 users on the network, and no more than 15 per AP. I have tried setting the internet port dat limits to 1gigabit, to match the connection to the TMG NIC, but this made no difference. also tried switching on and off various routing options within the Controller but nothing has made a difference. I know the problem is not with the TMG becuase we dont have any data throttling in place, and our main office LAN runs through it with no performance issues.
I just dont know where to check...I've seen similar issues on these forums but nobody seems to know what to do about it. the Manual is also no help for troubleshooting.
P.S. This thread has been moved from Communications, Wireless (Legacy ITRC forum) to MSM Series. - Hp forum Moderator
#wireless#MSM710
