  • 1.  MSM760 upgrade to 6.6.2.0
    Posted Dec 16, 2015 07:04 PM
    Hello all,
    I'm trying to upgrade my controller from version 6.4.0.0-B16925 to V6.6.2.0-B22792 and after the upgrade when the 96 APs MSM-430 that I have in the solution begin to download the firmware the controller response time changes from 1ms to between 200 and 500ms and some times a lost packaged and after one hour I only have 10 APs working the rest tried to download but the get timeout.
    I tried to upgrade to 6.6.0.0 but the same appended.
    Can anyone help me? I don't know what I can do more.
    Best Regards.
    #msm760
    #upgrade
    #fail
    #help
  • 2.  RE: MSM760 upgrade to 6.6.2.0
    Posted Dec 16, 2015 07:36 PM
    Hello.
    I believe you should have done the upgrade incrementally ...
    All APs are on the same network? Can you send us a log or print of how this scenario the update now?
  • 3.  RE: MSM760 upgrade to 6.6.2.0
    Posted Dec 17, 2015 07:23 AM
    Hello
    Most part of the APs are on the same network that the controler. The APs are all control local by the MSM760.
    I did the download of the firmware to the MSM760 via Web page and when the MSM restarts all the APs start to connect to the controller and requesting the firmware, past some time they get timeout and didn't upgrade. The APs that fail (almost all) tray so many times to upgrade but nothing, in one hour I only have 10 of 96 working.
  • 4.  RE: MSM760 upgrade to 6.6.2.0
    Posted Dec 22, 2015 05:51 AM
    Hmm. I did!
    As this status now? The antennas are automatically discovered by the Controller or you did the provisioning or DHCP to work with this discovery?
    In this case I suggest Reboot the AP and or maybe remove/rediscovery antennas. You can not make a debug?
