Kind of new to managing HP so forgive me if this has been answered before but I did search and couldn't find something that answered my question.
Hotel using a MSM760+MSM410 APs and I am seeing in the logs the following message. It seems to happen to all of the APs.
Software version: 6.2.1.0-17104 Hardware revision: B:48
Severity: Minor ID: 72 Device: AP5 Category: Controlled AP Type: AP is silent and possibly down Latest associated event: ID 1345: AP (name='AP 5') has started to offer wireless services First occurrence: 2015-05-14 00:52:26,215 Last change: N/A Cleared: 2015-05-14 00:53:39,623 Description: AP (name='AP 5') is silent. It may still be providing services but is unmanaged. Reason: (value='Secure connection to AP went down') Probable cause: The AP is not connected to the network, or is powered down. Recommended action: Make sure the device is powered and connected to the network. Make sure that the AP can discover the controller as well. Acknowledged: State: Cleared
I thought it was related to this post but that setting is disabled on the APs on the controller.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=mmr_kc-0119465&sp4ts.oid=5179584#bottom
Any logs of configuration settings I should attempting to look at ?
Maybe an newer firmware will fix this issue??
#MSM410#msm760#silent#AP
