Hello HP-Freaks,
I have MSM460 AP´s connected to a Team of MSM765 Controllers running this Firmware
Software version: 6.6.0.0-22530
I have the Problem that the reflector Software that uses the Bonjour Protocol (mDNS) will only work when the 2 WLAN Devices are connected to the same Radio on the same AP.
If one wlan device switch to another radio on the same AP they can not see each other in the Reflector software.
And Airplay did also not see the other device. All Devices are in the same VSC (SSID) and also in the same subnet.
I think that Bonjour Subnet- or VLAN-Gateway function in the Controller can´t help me in this case.
I didn´t found any Settings in the MSM765 Controller to activate this feature that it will work when the two WLAN devices are not on the same Radio and never mind on different AP´s.
Best Regards
Patrick
#bonjour#reflector#Airplay
