MSR Password Recovery??
  • 1.  MSR Password Recovery??
    Posted Jun 19, 2013 01:13 PM
    I have an MSR 2000 that I cannot access past the login screen because I don't know the password. Is there a way to default the MSR back to factory settings without logging into it?
  • 2.  RE: MSR Password Recovery??
    Posted Jun 19, 2013 02:14 PM
    Yes.
    Per the user guide, there is a factory reset procedure intended for devices that are up on poles and not easily reached.
    You hard cycle the power 6 times - waiting for the device to fully boot each time (as indicated by the status lights).
    On the 7th cycle the unit should boot up with a factory default configuration.
    You can also open a TAC case and a TAC engineer can help get you in if there is remote access to the device.
  • 3.  RE: MSR Password Recovery??
    Posted Jun 19, 2013 05:47 PM
    Thank you very much.
  • 4.  RE: MSR Password Recovery??
    Posted Dec 04, 2013 06:49 AM
    So in general there is no password recovery of an MSR like a controller?  The only option is to blow out the config?
  • 5.  RE: MSR Password Recovery??
    Posted Dec 04, 2013 07:42 AM
    Correct.
