Wired Intelligent Edge
last person joined: 5 hours ago
MSR Router inquiry about WAN Failover
  • 1.  MSR Router inquiry about WAN Failover
    Posted Apr 02, 2019 04:40 AM
    How can I do a wan failover in MSR router if the routers doesn't have connection to both isp? What can be the possible solution here?
  • 2.  RE: MSR Router inquiry about WAN Failover
    Posted Apr 03, 2019 09:43 AM
    Just looking at your diagram. I think you can use two solutions, the following:
    - Use tracking, see more details in link below:
    http://h22208.www2.hpe.com/eginfolib/networking/docs/routers/msrv7/cg/5200-3011_hi-avail_cg/content/index.htm
    - Play with route preferences
    But in this case your complete route must be gone. Tracking is much more dynamic
    In your diagram I can't see if you are using VRRP down or maybe you want to IRF your routers (that would be even easier I think). Since you need to make sure the clients will also follow the right path.
    Hope this will help you!
    Regards, Dobias
  • 3.  RE: MSR Router inquiry about WAN Failover
    Posted Apr 03, 2019 09:06 PM
    We're using VRRP for the 2 routers. So track can check if PLDT or Globe is down and automatically change the route to pldt or globe once the other is down?
  • 4.  RE: MSR Router inquiry about WAN Failover
    Posted Apr 03, 2019 09:12 PM
    And they also want to load balance voice and data traffic thats why we used vrrp so that vlan for voice vrrp master is router 2 and vlan for data vrrp master is router 1
  • 5.  RE: MSR Router inquiry about WAN Failover
    Posted Apr 04, 2019 01:11 AM
    Should we use vrrp, nqa for checking of internet and bfd for detecting if the physical status of uplink is up or down?
