last person joined: 5 hours ago
MSR virtual controller
  • 1.  MSR virtual controller
    Posted Mar 10, 2012 05:35 PM
    Hi all
    I've been investigating MSRs and have seen thay they are compatible with Airwave. However, the configuration/RF management is still not to clear to me. Do u guys know Is there any kind of virtual controller for MSR deployments? Or, on the contrary, do they have to be configured independently?
    Regards
    samuel
  • 2.  RE: MSR virtual controller
    Posted Mar 10, 2012 08:02 PM
    The MSR line of Access Points / Mesh Points runs a different OS than the Aruba Thin APs do.   That OS does not report back to a controller, virtual or otherwise.
    That being said, configuration can be streamlined for the MSR product line with our  Mesh Config (MC) application (available on support site...along with documentation for same)
    How many MSRs are you envisioning in your deployment ?
    JF
  • 3.  RE: MSR virtual controller
    Posted Mar 11, 2012 04:28 AM
    Hi
    Thanks for the swift reply. We were thinking about an initial deployment of 15 access points.
    Regards
  • 4.  RE: MSR virtual controller
    Posted Mar 11, 2012 02:17 PM
    Thanks Samuel.
    Check out the "MC" tool on the support site, I think it will help you out nicely.
