MSR4000 and Ant-5614
  • 1.  MSR4000 and Ant-5614
    Posted Jul 17, 2014 08:44 AM
    Hello's
    I had a quick question. I note that the config guide for the MSR4000 does not list the ant-5614 as a possible antenna while it does so for the MSR2000.
    My question is, why can't I use the 5614 with the MSR4000, while I can use it with the MSR2000?
    Thanks for your time,
    Sky
  • 2.  RE: MSR4000 and Ant-5614
    Posted Jul 18, 2014 06:32 AM
    You can use the 5614 with the MSR4000, Ii's likely an oversight on the documentation side. I have numerous deployments using multiple 5614s on a single MSR4K working just fine.
  • 3.  RE: MSR4000 and Ant-5614
    Posted Jul 18, 2014 08:30 AM
    Thanks much Jerrod,
    Sky,
