MST 200 Configuration
  • 1.  MST 200 Configuration
    Posted Nov 26, 2014 12:15 PM
    Hi all
    we are configuring two MST200 and we need that 2 vlans pass throught the antenas.
    This antennas are connected to a Nortel 3524 Switch.
    We have done the configs with the port on the switch to be trunk mode ( allowed both vlans) and also tried to trunk the port on Aruba to be alowwed both vlans.
    Is this sufficient to be able to have traffic on both vlans ?
    We are only having traffic on data vlan 1 , vlan 4 that is voip , is not getting to the other side.
    Since i am new to this MST´s , am I missing some config?
    Does Vlan 4 needs to have an Ip address?
    Regards
  • 2.  RE: MST 200 Configuration
    Posted Feb 20, 2015 08:45 PM
    your config seem to be correct,
    you do not need to configure an address IP in each VLAN unless you need that your AP become reacheble from both VLAN (without intervlan routing)
    Regards
  • 3.  RE: MST 200 Configuration
    Posted Feb 23, 2015 12:25 PM
    It seems it was a untagged pvid only setting. For now everything is working ok
    Regards
  • 4.  RE: MST 200 Configuration
    Posted Feb 28, 2015 08:06 AM
    good news :)
