Hell Community, I am looking for the MTBF info for the switchs serie 3810M.Somebody have the info ?? any link ??
The following table represents the MTBF information for Aruba 3810M Switches. The MTBF values are as of January 2018.
Product Number
Marketing Description
PH Product
PH Family
Predicted AFR / %
Predicted MTBF / Hrs
JL071A
Aruba 3810M 24G 1-slot Switch
3810-G Switches
Fixed Switches - L3 Gig
2.92
300,000
JL072A
Aruba 3810M 48G 1-slot Switch
3.14
278,981
JL073A
Aruba 3810M 24G PoE+ 1-slot Switch
2.3
380,870
JL074A
Aruba 3810M 48G PoE+ 1-slot Switch
3.3
265,455
JL075A
Aruba 3810M 16SFP+ 2-slot Switch
JL076A
Aruba 3810M 40G 8SR PoE+ 1-slot Switch
5.7
153,684
Hope this helps.
Thank You,
