last person joined: 3 hours ago
MTBF of Aruba IAPs
This thread has been viewed 24 times
  • 1.  MTBF of Aruba IAPs
    Posted Jul 16, 2013 09:54 AM
    Does anyone know where I can find the MTBF for IAP-105 access points? What about the MTBF for all IAPs models?
  • 2.  RE: MTBF of Aruba IAPs
    Posted Jul 16, 2013 01:53 PM
    Please contact your local Aruba Sales team for questions of this type.
  • 3.  RE: MTBF of Aruba IAPs
    Posted Jul 16, 2013 03:47 PM
    Aruba AP-105
    Predicted MTBF
    34.8 years / 304,653 hours @ 25C
  • 4.  RE: MTBF of Aruba IAPs
    Posted Jul 16, 2013 04:05 PM
    Thanks. Where did you get this information? I'd like to have this available for all IAPs for future reference. Chances are that the IAP-105 is not the only IAP that I will help deploy.
  • 5.  RE: MTBF of Aruba IAPs
    Posted Jul 16, 2013 04:07 PM
    By the way, this MTBF is for an AP-105. Are you stating that the MTBF is the same for an IAP-105? Although both devices are the same form factor, one could argue that the IAP-105 requires more resources to function in a cluster than an AP-105.
  • 6.  RE: MTBF of Aruba IAPs
    Posted Jul 16, 2013 04:14 PM
    The numbers are available to me internally.
    The MTBF numbers are the same for the AP-105 and IAP-105.
  • 7.  RE: MTBF of Aruba IAPs
    Posted Mar 18, 2019 08:01 AM
    I'd need the MTBF for AP-93 model.
    Thanks in advance
  • 8.  RE: MTBF of Aruba IAPs
    Posted Mar 18, 2019 02:07 PM
    MTBF for (I)AP-93 is 365k hours (at 25C).
    Telcordia SR-332 Issue 2, Method I (Parts Count), Case 3, GB/GC (Ground Benign, Controlled) environment.
  • 9.  RE: MTBF of Aruba IAPs
    Posted Dec 11, 2023 03:50 PM
    Can you tell me there i can get this information please .
    Steve smallwood@hpe.com
  • 10.  RE: MTBF of Aruba IAPs
    Posted Dec 11, 2023 05:51 PM
    For most current AP models, you'll find this info in the datasheet.
    Note that MTBF is a very pessimistic way to estimate the actual failure rate for the Aruba APs.
    365khrs would translate to an annual failure rate (AFR) of 2.4%. The (I)AP-93 never exceeded an actual AFR of 0.2% (based on warranty returns).
  • 11.  RE: MTBF of Aruba IAPs
    Posted Dec 12, 2023 07:03 AM
    Employees and partners can access the MTBF information on Arubapedia (for Partners).
