If I'm not mistaken there is no way to change the MSS on ArubaOS-Switch operating system (used into Aruba 5400R zl2, as example) but you can change the MTU on VLAN context:
jumbo frame enable
jumbo
[no] vlan VLAN-ID jumbo
Usage: [no] jumbo
Description: Labels this VLAN as a Jumbo VLAN, allowing you to pass packets up to 9220 bytes in size.
This is a VLAN context command. It can be called directly from the VLAN context or follow the 'vlan VLAN-ID'
Also check with show jumbos.
Original Message:
Sent: May 24, 2023 11:40 AM
Subject: MTU and mss 5400 series
HI ,
Is there any way to set MTU to 9000 on interface port on Aruba 5406 and change the mss value on vlan
like in cisco switch
interface Vlan10
ip tcp adjust-mss 1300
interface GigabitEthernet1/3
switchport access vlan 10
switchport mode access
mtu 9000
thanks
