Wired Intelligent Edge
System MTU routing on 6300
  • 1.  System MTU routing on 6300
    Posted Jul 22, 2022 10:05 AM
    I want to migrate from cisco 3600 series to CX 6300. There is system mtu routing command  applied on the cisco switch. In best practice, is the mtu has to set on every routed interface/SVI or is there any feature for globally configure for system mtu routing ?
    Thanks and regards
    Gibs
  • 2.  RE: System MTU routing on 6300
    Posted Jul 22, 2022 04:47 PM
    Hi Gibs,
    With Aruba AOS-CX platforms, the mtu needs to be set on the routed interfaces/SVIs.  We do not have a global designation, although, that certainly sounds like a nice enhancement.
    Corey
  • 3.  RE: System MTU routing on 6300
    Posted Jul 22, 2022 08:54 PM
    Okay Corey,
    Thank you for your info
    Sincerely,
    Gibs
  • 4.  RE: System MTU routing on 6300
    MVP GURU
    Posted Jul 23, 2022 03:48 AM
    Hi Gibs, I believe that this old thread worth to be read.
  • 5.  RE: System MTU routing on 6300
    Posted Jul 24, 2022 06:41 AM
    There is a follow-up here: this old thread
