last person joined: 10 hours ago
Multi-site deployment with InstantOS and Airwave
  • 1.  Multi-site deployment with InstantOS and Airwave
    Posted Nov 11, 2016 11:11 AM
    Hello guys,
    Currently, i'm doing a survey on WI-FI controllers. I am fairly new to the concept of AP controller and i am afraid that i could have misunderstood Airwave's purpose.
    The thing is that i would like to be able to deploy ,manage and provision APs in multiple offices (70), located all around the globe, and have a unique control panel in my Headquarter.
    Cisco has a feature called "Flexconnect" which does the trick. As far as I know if i want a similar feature for aruba products I need to use airwave.
    So i'm wondering if I set up an instantOS cluster (composed of 2 or 3 AP315) in each office and then set up the airwave appliance in my headquarter, would i be able to achieve what i want ? Or do i need another device/feature/controller ?
    Moreover, is this solution efficient ? Is there any other way to achieve what i want ?
    Ps: I don't want to use cloud based controller like Aruba Central.
    Xavier
  • 2.  RE: Multi-site deployment with InstantOS and Airwave
    Posted Nov 11, 2016 11:14 AM
    The short answer is yes...
    You can configure, upgrade, manage and monitor instant clusters across your whole company with Airwave.
