Multi user type authentication
  • 1.  Multi user type authentication
    Posted Apr 09, 2012 03:55 PM
    I'm trying to setup user auth on one of my S3500 wired ports and I must be missing something.
    I tested without applying the aaa profile to the interface to verify that DHCP is working.
    With the below configuration, and the aaa profile applied to the port, I do not even get an authentication window (using a MacBook Pro).
    Logon role ACL
    ip access-list stateless logon-control-stateless
    user any udp 68 deny
    any any svc-icmp permit
    any any svc-dns permit
    any any svc-dhcp permit
    any any svc-natt permit
    ! Authenticated "dorm-wired" user role ACL
    ip access-list stateless allowall-stateless
    any any any permit
    ! My authenticated user, placed on vlan 2
    user-role dorm-wired
    vlan 2
    ! My default role user, placed on vlan 3
    user-role Post-Auth-Default
    vlan 3
    ! My logon role, limited access
    user-role logon
    ! My dot1x profile, using the interal database for testing purposes
    aaa authentication dot1x "wired-dorm"
    termination enable
    ! My server-group, internal database
    aaa server-group "auth-internal"
    auth-server Internal
    set role condition role value-of
    ! My aaa profile
    aaa profile "dorm-wired"
    authentication-dot1x "wired-dorm"
    dot1x-default-role "Post-Auth-Default"
    dot1x-server-group "auth-internal"
    ! Applied to the client interface, switchport mode is access
    interface gigabitethernet "0/0/5"
    aaa-profile "dorm-wired"
    switching-profile "client"
  • 2.  RE: Multi user type authentication
    Posted Apr 10, 2012 05:08 PM
    The complete configuration is not pasted, for the configuration of interface g0/0/5,
    do you have "no trusted port " ?   It will put the port in untruated mode and aaa will kick in.
    Note: I guess you want to put non-authenticated user in  role "dorm-wired", if this is the case,
    in the aaa profile,  the "initial role dorm-wired" need to add to it otherwise the "default" role will be used.
  • 3.  RE: Multi user type authentication
    Posted Apr 10, 2012 06:47 PM
    Yes, trusted port can most likely be the issue here. Also, to be sure once the port is untrusted, if you are using local-userdb can you run  "aaa user delete all" and "clear mac-address-table". It also is a good idea to disable/enable the interface on the MacBook.
    If that still does not help, It would be great if we can get the output of "show log user", "show dot1x supplicant-info" and "show auth-tracebuf" with complete configs for further debugging.
    ATM
  • 4.  RE: Multi user type authentication
    Posted Apr 11, 2012 09:54 AM
    Abhinethra and Gcui, thanks setting the port untrusted did the trick.
