Hi Victor,
we have tried to keep this solution on the Management of the MM and controllers as simple as possible, i.e. all in the one subnet, as they are connected to an Cisco APIC (which is tricky enough :) )
I have attached a basic screen shot of the MM where
mm1 & mm2 clustered i.e. using x.x.x.40 vip with .41 and .42
WLC01 & 2 Clustered x.x.x.51 vip with .51 and 52
WLC03;4&5 vip x.x.x.55 with .56-58
we would like to create AP groups for the corporate sites advertise both Corp and Guest and use multizone to through the data traffic to the Guest cluster. (which seems possible) but we are currently having issues with an error that mention not compatible with HA and also in the AP group the profiles menu on the right hand side not there ( which is in Aruba OS vids on youtube - Herman )
thanks
Dave
![Capture-MM.PNG Capture-MM.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/7ae00a83a94e47a5bc28156b3776cff0_04e9f6ebf9c64cb4a67dda265d230bba)
