Comware
Multicast issue in 5710 IRF
  • 1.  Multicast issue in 5710 IRF
    Posted Apr 21, 2023 11:44 AM
    I have project for real time video system (6pcs of about 5Gbps per video multicast stream transmitters and 25 receivers) which should run IRF instance containing three 5710's connected togeteher to circle topology with 100G fiber links. Switches are running at latest fw.
    Configurations for IGMP snooping/querier, ip interface etc and IRF seems to work fine but today I tested first time to connect video gear (IDK Ninjar stuff) I noticed that multicast is flooding all over the ports while it should not.
    "Show igmp-snooping" shows (IRF vlan 9 has ip 192.168.2.1):
    IGMP snooping information: VLAN 9
     IGMP snooping: Enabled
     Drop-unknown: Enabled
     Version: 3
     Host-aging-time: 260s
     Router-aging-time: 260s
     Max-response-time: 10s
     Last-member-query-interval: 1s
     Querier: Enabled (IP:192.168.2.1, Expires: 00:00:58)
     Querier-election: Disabled
     Query-interval: 60s
     General-query source IP: 192.168.2.1
     Special-query source IP: 192.168.2.1
     Report source IP: 192.168.2.1
     Leave source IP: 192.168.2.1
     Host-tracking: Disabled
     Dot1p-priority: --
     Router-port-discard: Disabled
     Proxy: Disabled
     Peer-link interface: -
     Which looks quite ok?
    Is there something more to know when configuring multicast to IRF? Or should I break IRF to three separate switches?
    Jori Luoto
    AV-IT Specialist
