multiple bandwidth contracts
  • 1.  multiple bandwidth contracts
    Posted Apr 15, 2015 09:04 AM
    Would there be any issues in applying both a user and SSID bandwidth restriction to a client?
  • 2.  RE: multiple bandwidth contracts
  • 3.  RE: multiple bandwidth contracts
    Posted Apr 15, 2015 09:42 AM
    Thanks, It doesn't say whether there would be issues or what they might be. My customer would need an explanation rather than "you probably shouldn't".
  • 4.  RE: multiple bandwidth contracts
    Posted Apr 15, 2015 01:02 PM
    What cjoseph was trying to explain is that it could be very confusing to troubleshoot an issue when both are applied.
    Using the bandwidth contract gives you the ability to rate limit per user or per role but the traffic management gets applied per VAP/RF Band if you have several VAPs applied under your AP-Group .
    He suggested just using the bandwidth contract under the user-role will be more effective but of course it will depend on what you are trying to do.
    What are you trying to do?
  • 5.  RE: multiple bandwidth contracts
    Posted Apr 16, 2015 05:05 AM
    I'm trying to apply both a user and a VAP bandwidth limit.
  • 6.  RE: multiple bandwidth contracts
    Posted Apr 16, 2015 05:39 AM
    MattF,
    What is the use case for applying both?  You can certainly configure it, but it might not fit the use case.
