multiple controllers on same network
  • 1.  multiple controllers on same network
    Posted Nov 21, 2019 02:44 AM
    hi,
    i do have multiple virtual controllers on my network. When i was rebooting  iaps, some of them goes to wrong  controller. Then i deleted form that vc but they are still going to wrong vc and now i cant  even see them on that controller info panel. Where i can get them back to list?
  • 2.  RE: multiple controllers on same network
    MVP EXPERT
    Posted Nov 21, 2019 05:28 AM
    Virtual Controller should be separated by broadcast domains. All IAPs in a single broadcast domain will form a single cluster unless configured as a standalone IAP.
  • 3.  RE: multiple controllers on same network
    Posted Nov 21, 2019 05:43 AM
    thanks for answering. So is better to set 255.255.255.255 for both vc?
    i put also default gateway ip to second vc, because in some reason i dont see it from my office. i only see it when i connect diretly to that switch were they are connected to.but still that not work. Now i cant remove that gateway ip... if i want to join these virtual contorlers to only one vc. do i need to set mask 255.255.255.0?
  • 4.  RE: multiple controllers on same network
    MVP EXPERT
    Posted Nov 21, 2019 05:48 AM
    Your VC should be a single IP address. So for example:
    -- VC Cluster 1 --
    192.168.1.0/24 - Broadcast Domain
    192.168.1.1 - VC
    192.168.1.2 - IAP
    192.168.1.3 - IAP
    -- VC Cluster 2 --
    192.168.2.0/24 - Broadcast Domain
    192.168.2.1 - VC
    192.168.2.2 - IAP
    192.168.2.3 - IAP
  • 5.  RE: multiple controllers on same network
    Posted Nov 25, 2019 07:53 AM
    Thanks for answering me!
