Multiple DURs per port
  • 1.  Multiple DURs per port
    Posted Sep 11, 2018 11:43 PM
    Hello team,
    I'm unable to find documentation concerning multiple downloadable user roles to a single switch port. The Wired Guide seems to refer to a local user role for VOIP products.
    Use case: PC or Printer connected between a VOIP product. Currently, CPPM is configured to return a VOIP DUR (with tagged and untagged VLAN - I know the latter is an issue) and then a role specific DUR based on user/machine attribute for the device authenticating behind it.
    Such a design doesn't seem probable based on my experience with AAA products, and I cannot find any documentation....thoughts?
  • 2.  RE: Multiple DURs per port
    Posted Sep 11, 2018 11:47 PM
    Roles are assigned by MAC address. Simply configure the policy in ClearPass to return the appropriate role for each device/user type following the Solution Guide for Wired Policy Enforcement.
  • 3.  RE: Multiple DURs per port
    Posted Sep 11, 2018 11:53 PM
    Gotcha, DURs will then take a "user" instead of "port" based approach.
    Is there any documentation on DUR ACL size limitations and/or limitation on the number of DURs assigned in total? Or is it just going to be dependent on switch model ACL capacity either locally or through IDM?
  • 4.  RE: Multiple DURs per port
    Posted Sep 11, 2018 11:59 PM
    Yes, user roles are per user.
    Regarding switch capacity, I would recommend asking that in the switching forum. I don’t know the answer.
  • 5.  RE: Multiple DURs per port
    Posted Sep 12, 2018 12:00 AM
    Thanks Tim. Enjoy your travels!
