Multiple Gateways on AP's
  • 1.  Multiple Gateways on AP's
    Posted Sep 13, 2018 12:02 PM
    Please find attached a diagram which I think represents what I want to achieve here (if it’s possible).
    In a nutshell ... to regarding specific hosts as the gateway, DNS server and DHCP server for each SSID configured on the Aruba units. (Sound about right?)
    Please could you let me know if this is possible without running and installing extra AP’s on each level
  • 2.  RE: Multiple Gateways on AP's
    Posted Sep 13, 2018 12:14 PM
    yes, possible.
    Put 192.168.10.0/24 network in VLAN 10
    Put 192.168.20.0/24 network in VLAN 20
    Map SSID Crew to VLAN 10
    Map SSID Client to VLAN 20.
    You have to configure VLANs at switch and within wireless infrastructure (controller or VC if using instant APs).
    Ports of APs have to be tagged correctly if instant. otherwise ports of controller.
    If you need traffic between crew server and client server, some type of router (or firewall) will be needed.
    Either put wireles management in crew vlan or create a third management vlan.
    Kind regards, Jörg
