Wired Intelligent Edge
  • 1.  Multiple Instance Spanning Tree running configuration question
    Posted Nov 07, 2012 09:17 AM
    I have a few Procurve 5412s running MST and firmware 15.08.0013.  From what I can tell, it appears to be configured correctly, however when I run the command "show run" against those devices and compare it to my 3500yls the output is a bit strange.  I have not set up multiple VLANs on the switch and am using VLAN 1 for everything until we finalize our new network designs.  I am using instance 1 for MST instead of the default of 0.
    It seems that when I plug a cable into a port on the 5412s the similar lines appear in my running config to those below.  I do not see this behavior on my 3500yls.  These ports are not uplinks to any other switch, just edge ports.  I do have admin-edge-port set.
    spanning-tree instance ist C8 path-cost 20000
    spanning-tree instance ist L24 path-cost 200000
    Is this normal behavior?
    #Spanningtree
    #mst
  • 2.  RE: Multiple Instance Spanning Tree running configuration question
    Posted Nov 09, 2012 05:43 AM
    If you only have on vlan, there's not much point in using mstp, becuase the purpose of mstp is to use different path's for different vlans.
    The path-costs are normal. These are the default path-costs based on the link-speed:
    2 000=10gb
    20 000= 1 gb
    200 000= 100 mb
    2 000 000=10mb
    So if you do not configure it manually, the path-cost for a 1 gb link will be 20 000.
    If you can explain why you want to use mstp and what it is you want to achieve it would be easier to help.
    K.
  • 3.  RE: Multiple Instance Spanning Tree running configuration question
    Posted Nov 09, 2012 03:56 PM
    I am in the process of adding multiple VLANs to the network and will be setting up the full redundancy with VRRP so it will be needed here very soon.  I know the port costs, but just wondering why they are showing up in my running config when I didn't set them.  Is this something because I just have 1 VLAN at the moment or something with the 5412s?
  • 4.  RE: Multiple Instance Spanning Tree running configuration question
    Posted Nov 12, 2012 10:17 AM
    It's because you have enabled MSTP. All links have path-cost, it's just a matter of using the default values or if you override them manually.
    A link will always have a link-cost and if you don't set it manually, it will use the default values:
    http://en.wikipedia.org/wiki/Spanning_Tree_Protocol
    K.
