Multiple "memberOf" AD Attributes
This thread has been viewed 24 times
  • 1.  Multiple "memberOf" AD Attributes
    Posted Sep 22, 2022 06:43 AM
    Hi All,
    I got a case where I need to extract out the memberOf attribute from Microsoft AD to use it as Authorization rule, but when I query the AD, this object has two memberOf's (shown two rows and every row has different value).
    When checked to AD, this object has multiple 'AD group' under the "memberOf" tab, which means it is member of two OU so-called.
    I tried to alias these two memberOf into separate rule, but only one shows up.
    I don't know how or when this memberOf show as the query return, because for example if one object only has one memberOf or none memberOf, one object to another will have different parameter ID of memberOf, right ? (or how is it exactly, not AD expert)
    When the endpoint authenticates, at the Input attribute @ Access Tracker, I can only see one of it.​
    So anyone knows how to query the exact memberOf we wanted ?
    PS: I am not in charge of the AD, and the customer's AD 99.9% won't change (or we can't change), so we need to find a way.
    (Attached some screenshots)
  • 2.  RE: Multiple "memberOf" AD Attributes
    Posted Sep 22, 2022 07:04 AM
    Hi
    It's normal that you have multiple memberOf  rows. If a user is a member of 20 groups you will have 20 of them.
    In the role mapping or enforcement you should use the condition Contains instead of Equals.
    See the attaches screenshot
    Best Regards
    Jonas Hammarbäck
    ACCX #1335, ACMP, ACDP, ACNSP, ACEP
    Aranya AB
  • 3.  RE: Multiple "memberOf" AD Attributes
    Posted Sep 22, 2022 07:30 AM
    Or even better, use AD:Group EQUALS groupname, instead of memberOf CONTAINS in your role mapping or enforcement.
    AD:Group EQUALS groupname matches if the user is member of that group.
  • 4.  RE: Multiple "memberOf" AD Attributes
    Posted Oct 16, 2022 05:09 PM
    Hi, thanks for the answer it helps me too.
