Wired Intelligent Edge
Multiple ports configured for VSF
  • 1.  Multiple ports configured for VSF
    Posted Jun 04, 2018 03:43 PM
    I have 2 2930f switches I want to connect with VSF. I have configured ports 1-4 on both switches. sho vsf shows only 1G for port speed. Am I using all four ports in the VSF? Is it load balancing?
    CCA_CORE# sho vsf
    VSF Domain ID : 1
    MAC Address : d06726-3bbd0b
    VSF Topology : Chain
    VSF Status : Fragment Active
    Uptime : 0d 3h 39m
    VSF MAD : None
    VSF Port Speed : 1G
    Software Version : WC.16.03.0005
    Mbr
    ID MAC Address Model Pri Status
    1 d06726-3bbd00 Aruba JL262A 2930F-48G-PoE+-4SFP Sw... 128 Commander
    2 d06726-3c0000 Aruba JL262A 2930F-48G-PoE+-4SFP Sw... 128 Standby Booting
    CCA_CORE(config)# sho vsf lin det
    VSF Member: 1 Link: 1
    Port State
    1/1 Up: Connected to port 2/1
    1/2 Up: Connected to port 2/2
    1/3 Up: Connected to port 2/3
    1/4 Up: Connected to port 2/4
    VSF Member: 2 Link: 1
    Port State
    2/1 Up: Connected to port 1/1
    2/2 Up: Connected to port 1/2
    2/3 Up: Connected to port 1/3
    2/4 Up: Connected to port 1/4
  • 2.  RE: Multiple ports configured for VSF
    Posted Jun 04, 2018 04:41 PM
    The ports linking the two switches are 1Gig ports, correct?
  • 3.  RE: Multiple ports configured for VSF
    Posted Jun 04, 2018 05:03 PM
    Correct, they are 1G ports.
  • 4.  RE: Multiple ports configured for VSF
    Posted Jun 04, 2018 05:08 PM
    The show vsf command is showing the speed of the physical port type, not the aggregate speed of the trunk. This output looks correct to me, and the four links between the commander and standby should be load balanced.
  • 5.  RE: Multiple ports configured for VSF
    Posted Jun 04, 2018 05:24 PM
    Great. I appreciate it.
