Multiple Vendor with internal IAP 305 DHCP-Server possible?
  • 1.  Multiple Vendor with internal IAP 305 DHCP-Server possible?
    Posted 6 hours ago
    Hello Airheads,
    we have this actual Situation:
    we are using a IAP 305 to prestage a specific devicename "abc".
    It provides Option 43 and a ftp Server to which "abc" should connect.
    Type 43 - 10642 2 x.y.z.a abc abc/yyy abc/www ftp
    Now we got a second device with device name "abcplus"
    Option looks like this:
    Type 43 - 10642 2 x.y.z.b abcplus abcplus/yyy abcplus/www ftp
    Now our problem:
    How can we configure the IAP, to use both option and differentiate the vendor/device?
    when we use both options in GUI DHCP-Server dialogue, it only will accept one of both options.
  • 2.  RE: Multiple Vendor with internal IAP 305 DHCP-Server possible?
    Posted 3 hours ago
    No, you should not use the dhcp-server in IAP, except in a few corner cases like Guest access and IAP-VPN/Branch.
    Configuration options are really limited for that reason.
  • 3.  RE: Multiple Vendor with internal IAP 305 DHCP-Server possible?
    Posted 2 hours ago
    Understood, thanks for your reply.
    So then, we'll look for alternatives.
    Dennis Schug
