Multiple VLAN setup with AP 105's
  • 1.  Multiple VLAN setup with AP 105's
    Posted Sep 26, 2013 09:49 AM
    We are replacing our entire wireless infrastructure with AP 105's and redundant 7220's
    What we would like to do is when adding the AP's to our current switches, we assign 1 VLAN to the switch which tunnels the traffic back to the controller, and sends the information out on the correct VLAN from the controller.
    As an example
    AP's are on VLAN 10
    Controller is Trunked on VLAN 10,20,30
    Client 1 connects to SSID1 on AP which is on VLAN 20.  Traffic is tunneled over VLAN 10 from the AP to the controller and at the controller is sent out on VLAN 20.
    Client 2 connects to SSID2 on AP which is on VLAN 30.  Traffic is tunneled over VLAN 10 from the AP to the controller and at the controller is sent out on VLAN 30.
    The reason we are asking this, is so we do not have to set up all the static ports on the switch's trunked with multiple VLANs for each AP.
    Is this possible with the AP's/Controller?
    #7220
  • 2.  RE: Multiple VLAN setup with AP 105's
    Posted Sep 26, 2013 11:18 AM
    Sure, this is easy to accomplish on the Aruba controller.
    Put the APs in tunneled mode (default) and configure each VAP (Virtual AP) with the VLAN 20 and 30 as desired.
    The Trunk at the controller is key.   No need to trunk/add VLAN 20/30 to the LAN ports that the APs plug into.   Simplicity!
    JF
  • 3.  RE: Multiple VLAN setup with AP 105's
    Posted Sep 26, 2013 11:19 AM
    Beautiful, thank you very much.
  • 4.  RE: Multiple VLAN setup with AP 105's
    Posted Dec 09, 2016 08:46 AM
    We have two networks (ssid's) across 8 AP's in our cluster. We want wireless network 1 to be in vlan30 and wireless network 2 to be in vlan40. We also use a network based dhcp server at the router for each virtual interface/gw. Do we need each switchport to be a trunk port allowing both vlans, or does just the switchport connected to the virtual controller AP need to be a trunk port allowing these vlans? Also, does each wireless network (ssid) need to have a static vlan id set?
