I added VLAN 80 on the controller, although it shouldn't have any impact on this issue. All VLANs are up:
Vlan Status
VlanId IPAddress Adminstate Operstate PortCount Nat Inside Mode Ports AAA Profile
1 172.16.0.254/255.255.255.0 Enabled Up 7 Disabled Regular GE1/1-7 Pc0-7 N/A
80 10.0.80.7/255.255.254.0 Enabled Up 1 Disabled Regular GE1/0 N/A
82 10.0.82.7/255.255.255.0 Enabled Up 1 Disabled Regular GE1/0 N/A
83 10.0.83.7/255.255.255.0 Enabled Up 1 Disabled Regular GE1/0 N/A
196 10.0.199.34/255.255.252.0 Enabled Up 1 Disabled Regular GE1/0 N/A
The Cisco switch has no IP addresses and I can't add any, but I can ping the PA addresses from the controller:
(RCH_AMC4) #ping 10.0.82.1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.0.82.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.746/2.7964/10.07 ms
(RCH_AMC4) #ping 10.0.80.1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.0.80.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.914/2.8956/10.682 ms
(RCH_AMC4) #ping 10.0.83.1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.0.83.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.846/1.9918/6.351 ms
(RCH_AMC4) #ping 10.0.196.1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.0.196.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.929/1.8868/5.587 ms
I can also ping them from the Cisco switch. I'm thinking it's an issue on the PA - found this post on a similar issue when connected to an ASA firewall:
http://community.arubanetworks.com/t5/Wireless-Access/Controller-responding-to-traffic-under-wrong-VLAN/td-p/42228
