Wired Intelligent Edge
Multiprotocol BGP on 5400r, 3810M switches
  • 1.  Multiprotocol BGP on 5400r, 3810M switches
    Posted Jun 14, 2019 05:05 PM
    Hello there,
    I'm trying to find out if Aruba switches 5400r ad 3810M series support multiprotocol BGP.
    Thanks!
  • 2.  RE: Multiprotocol BGP on 5400r, 3810M switches
    MVP GURU
    Posted Jun 15, 2019 10:01 AM
    With the formula "multiprotocol BGP" are you meaning IPv6 other than IPv4? otherwise can you clarify a little bit better what do you mean?
  • 3.  RE: Multiprotocol BGP on 5400r, 3810M switches
    Posted Jun 15, 2019 04:11 PM
    Hi parnassus,
    Well the question would be, are the switches RFC4760 compliant?
  • 4.  RE: Multiprotocol BGP on 5400r, 3810M switches
    Posted Jun 16, 2019 03:19 AM
    As per your query, Aruba 8320,8325,8400 high-end series switches support M-BGP as per RFC4760, but Aruba 5400 series switches won't support M-BGP as per RFC4760
    Best Regards,
    Suresh Reddy
    ACMA, ACMP,ACSA
  • 5.  RE: Multiprotocol BGP on 5400r, 3810M switches
    MVP GURU
    Posted Jun 16, 2019 04:01 AM
    Exactly, a list of BGP related RFCs supported by Aruba 5400R zl2 and Aruba 3810M is:
    BGP
    • RFC 1997 BGP Communities Attribute
    • RFC 2918 Route Refresh Capability
    • RFC 4271 A Border Gateway Protocol 4 (BGP-4)
    • RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP)
    • RFC 5492 Capabilities Advertisement with BGP-4
    and, as already pointed out, RFC 4760 is not among them.
