  • 1.  Multizone AP
    Posted Jun 23, 2020 07:58 AM
    Dear airheads community,
    I have one problem with Multizone configuration on ArubaOS 8.3.0.13 Controllers. Primary Zone is standalone controller and in Data Zone are 2 standalone Controllers in HA. When I join AP to the Multizone group it shows in Primary Zone as up and running, but on Data Zone Controllers is this error:
    stm[7418]: <399803> <7418> <ERRS> |stm| An internal system error has occurred at file sapm_ap_mgmt.c function sapm_proc_hello_req line 15782 error AP(Multizone_AP) HELLO was rejected because HA is not supported for datazone..
    Is this configuration really not supported ? I didnt find that in any guides or requirements.
    Thanks and best regards
    Vaclav
  • 2.  RE: Multizone AP
    MVP GURU
    Posted Jun 23, 2020 08:28 AM
    Controllers running in HA is supported. However, if the data zone is managed by a Mobility Master, you could cluster the two controllers and it would be supported. Example Multizone setups are like the following. The Multizone setup can support up to 4 Data Zones.
    1. Primary Zone:   Standalone 1
        Data Zone:        Standalone 2
    2. Primary Zone:  Controller Cluster
    3. Primary Zone:   Controller Cluster
        Data Zone 1:    Controller Cluster
        Data Zone 2:     Standalone
  • 3.  RE: Multizone AP
    Posted Jun 23, 2020 08:33 AM
    Thanks for reply. My configuration is:
    Data Zone: 2 Controllers HA cluster without MM
  • 4.  RE: Multizone AP
    MVP GURU
    Posted Jun 23, 2020 08:51 AM
    Yea that would be an unsupported configuration.
  • 5.  RE: Multizone AP
    Posted Jun 23, 2020 09:25 AM
    And if I switch the Zones or if I add another controller to the Primary Zone and create another HA cluster, it can be solution ? Or the absence of MM is main issue?
  • 6.  RE: Multizone AP
    MVP GURU
    Posted Jun 23, 2020 09:29 AM
    Yea the absence of the MM is your redundancy issue. Your setup will allow only a standalone Primary Zone Controller, and a standalone Data Zone Controller.
  • 7.  RE: Multizone AP
    Posted Jun 23, 2020 09:50 AM
    ok, thats bad. And what if I establish connection to only one member of the HA cluster, instead of the VRRP IP address?
  • 8.  RE: Multizone AP
    MVP GURU
    Posted Jun 23, 2020 09:57 AM
    I'm not 100% sure on that. You may still receive an error message because its part of an HA pair.
  • 9.  RE: Multizone AP
    Posted Jun 24, 2020 04:20 AM
    Thanks for your answers Dustin.
    Best regards
    V.
  • 10.  RE: Multizone AP
    Posted Jun 25, 2020 12:23 PM
    Finally I solved it by removing the HA Group and left there VRRP with master redundancy only. After few seconds multizone AP connect to the Data Zone.
