My AP after provisioning still showing in provisioning list. Any idea?
  • 1.  My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 12:01 PM
    My AP (205) after provisioning still showing in provisioning list. Any idea?
  • 2.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 12:07 PM
    Are there any flags?
  • 3.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 12:36 PM
    Thanks for reply.
    Yes, There is a flag "I - Inactive".
    PC
  • 4.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 03:50 PM
    Usually when the AP show the flag “I” or “Inactive”, that mean that the AP is not broadcasting any SSID
    That may be caused by
    • VAP Inactive
    • VLAN not mapped to the VAP
    • AP provisioned with the “default” AP group (without any modification).
  • 5.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 12:39 PM
    Hi friend,
    let me get more clarity, is that AP listed when you select "AP installation" in GUI ? if yes please confirm whether the AP group is changed to the new AP-Group or still showing as default.
    Please clarify.
  • 6.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 12:43 PM
    Ok. If the flag is I then look at the following configuration,
    1. Is the VLAN mapped to the VAP is available in the controller ?
    2. put show profile-errors to check for errors.
    Please clarify
  • 7.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 12:58 PM
    Yes, the AP is listed in "AP Installation".
    The AP group is changed.
    And I put the "Master Controller IP".
    Others options not touched.
    PC
  • 8.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 01:11 PM
    Check whether the VAP is properly configured and mapped. check the VLAN mapped to the VAP.
    use show profile-errors to find some reasons.
  • 9.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 02:54 PM
    Are there any licenses installed?
  • 10.  RE: My AP after provisioning still showing in provisioning list. Any idea?
    Posted Jan 06, 2015 02:55 PM
    even good provisioned APs will show up in that list.
    the I flag isn't good, you could check your logs to see if you can find a reason for it there.
