Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
My Aruba IAP Dashboard shows signal strength zero
  • 1.  My Aruba IAP Dashboard shows signal strength zero
    Posted 22 days ago
    In another environment we're using Aruba IAP 207 and 305. We found some APs (AP 207) shown signal strength as zero(see attached file).  And clients can connect to that AP.  The rest of APs (AP207 , 303, 305) doesn't have this behavior.
    Has anyone found this behavior in your environment? or if you have a solution, please share us.
    Thanks.
    Lee.
  • 2.  RE: My Aruba IAP Dashboard shows signal strength zero
    Posted 22 days ago
    what firmware version are you running?
  • 3.  RE: My Aruba IAP Dashboard shows signal strength zero
    Posted 22 days ago
    Current running version is 8.6.0.11_80920. In addition, AP505s are running together with this cluster.
  • 4.  RE: My Aruba IAP Dashboard shows signal strength zero
    Posted 22 days ago
    it could be a UI thing, before upgrading to the latest version on 8.6.0.x train which is 8.6.0.17 see if you can see it from the CLI
    use this command from the VC
    "show clients"
  • 5.  RE: My Aruba IAP Dashboard shows signal strength zero
    Posted 11 days ago
    After upgraded to version 8.9, there's no any zero value in dashboard. Thanks
