MY IAP207 Not Appear In My Current Virtual Controller
  • 1.  MY IAP207 Not Appear In My Current Virtual Controller
    Posted May 05, 2017 11:07 AM
    Hi All,
    I have some problem at my work place.
    Currently we are using IAP104 & IAP105.
    Now, just buy 3 units of IAP207.
    I try to configure IAP207 but when access the SSID "instant" & get into 10.10.0.250 to do configuration the connection will lost. It happen every time I try to do configuration.
    In other hand, the instant AP not appear in our current virtual controller.
    Some body please help me rectify this issue.
    Thanks you, Nizam
  • 2.  RE: MY IAP207 Not Appear In My Current Virtual Controller
    Posted May 06, 2017 10:40 AM
    Hi Nizam,
    IAP 207 runs on a difference image than 104/105. So, it will not join the cluster.
    The minimum supported firmware for IAP 207 is 4.3.1.0.
    http://www.arubanetworks.com/assets/ds/DS_AP207Series.pdf
    However, IAP 104/105 are not supported on from 4.3.0.0, So, you can not have IAP 104/105 & IAP 207 in the same cluster.
    Next Action Step:
    1. Bring up your IAP 207 cluster on a different vlan than the IAP 104/105.
    This will allow you to access & configure it.
  • 3.  RE: MY IAP207 Not Appear In My Current Virtual Controller
    Posted May 06, 2017 03:41 PM
    Hi Nitesh,
    Kindly assist me on how to Bring up your IAP 207 cluster on a different
    *P* *Please consider your environmental responsibility - think before you
    print!*
    “CONFIDENTIAL NOTICE & EMAIL DISCLAIMER:
    This e-mail (and any attachment hereto) are private and confidential and may
    contain proprietary or privileged information. Please also note the Email
    Disclaimer set out in Chemical Company of Malaysia Berhad’s (5136-T)
    website (go to http://www.ccmberhad.com/email_disclaimer/)”
  • 4.  RE: MY IAP207 Not Appear In My Current Virtual Controller
    MVP EXPERT
    Posted May 07, 2017 06:18 AM
    Hi, plug the 207 into a different vlan + subnet which is not the same as the 104/105.
  • 5.  RE: MY IAP207 Not Appear In My Current Virtual Controller
    Posted May 08, 2017 10:10 PM
    Thank for your response guys..
    However, I have further inquiry on this.
    Is it mean I has to create another SSID?
    currently I have 1 SSID which been used by all staff here and colleagues
    from HQ.
    In order to have additional SSID seem not practical for us as we try to
    maintain with 1 SSID only.
    You advice very much appreciated.
    print!*
