my "show conf" not natch with my "show run" when I restore a backup
  • 1.  my "show conf" not natch with my "show run" when I restore a backup
    Posted Aug 14, 2013 02:59 PM
    my network is formed for one aruba 3600 and 41 Ap's, did a flash memory backup and restore on a Model 3200 controller, however when you check the controller configuration in 3200, many settings are not passed, settings such as the user role, if I check the configuration with the command "show conf" and the settings appear correct and complete, but if I check the configuration with the command "show run" and the configuration is incomplete.
    #3200
    #3600
  • 2.  RE: my "show conf" not natch with my "show run" when I restore a backup
    Posted Aug 14, 2013 03:24 PM
    Did u remembered to install all licenses (such pef or others)
    before deploying your old conf.
  • 3.  RE: my "show conf" not natch with my "show run" when I restore a backup
    Posted Aug 14, 2013 06:47 PM
    excellent, thanks,
    the right steps were:
    First, copy the backup of the flash to the new controller.
    second: flash restore the new controller
    third, copy and restore licenses for the new controller
    restart the controller
  • 4.  RE: my "show conf" not natch with my "show run" when I restore a backup
    Posted Aug 19, 2013 09:05 AM
    yes just make sure that the licenses have been transfered to a new serial number if you are transferring to a "new" controller.
