My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
  • 1.  My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 27, 2013 11:29 PM
    hi expert ,
    anyone can help me to fixed this problem?
  • 2.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 27, 2013 11:38 PM
    Instant APs will only join other Instant AP clusters. The only relation
    with a mobility controller would be a VPN connection which would need to be
    manually configured.
  • 3.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 27, 2013 11:42 PM
    Hi Tim,
    Means, it cannot discover by itself? can you give me flow how to do it? i having problem that, posible i must downgrade my AP instant 105 aruba?
    tq for your fast reply.
  • 4.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 27, 2013 11:45 PM
    Are you trying to set up an instant cluster or do you want the IAP-105 to
    work as a normal controller AP?
  • 5.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 27, 2013 11:48 PM
    i want the IAP-105 to work as a normal AP. and connect to wireless controller aruba 2400 model. the problem is, i cannot discover the IAP-105 in Aruba 2400 Model Wireless Controller.
  • 6.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 27, 2013 11:52 PM
    Go to the IAP GUI by connecting to the instant SSID and then going to
    instant.arubanetworks.com in the browser. Then go to Maintenance > Convert
    then select Campus APs managed by a mobility controller from the drop down
    box.
  • 7.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 28, 2013 12:35 AM
    An IAP can be converted to a Campus AP and Remote AP only if the controller is running ArubaOS 6.1.4 or later.
    Unfortunately, your 2400 can only run up to AOS 5.x.  As such, it cannot utilize IAPs as Campus APs.
  • 8.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 28, 2013 01:22 AM
    Hi Mr Marcus,
    So the solutions is? i must downgrade my IAP 105  to 5.0.0 version and can discover by wireless controllet 2400 model 3.4.0 version? it is ?
  • 9.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 28, 2013 01:24 AM
    The IAP cannot be downgraded to 5.x code.
  • 10.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 28, 2013 01:29 AM
    Hi mr,
    orait, but i must have officially report from aruba, who decide the IAP 105 cannot be downgrade. Which way i can get a report sir?
  • 11.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Dec 04, 2013 01:55 AM
    Assalam o Alaikum Ahmad,
    As Marcus said earlier if you want you IAP to convert in Campus AP (that work with controller); your controller should have at least 6.1 OS install on controller. But unfortunately you 2400 controller can not be upgraded to 6.1 OS. that is why your IAP can not work as campus AP with your controller.
  • 12.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Jan 07, 2014 01:23 AM
    Waalaikumusalam ,
    Can  i get a officialy report for this thing from Aruba ? i need explain to User with Report. Can you help me?
  • 13.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Jan 07, 2014 01:24 AM
    Waalaikumusalam ,
  • 14.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Jan 07, 2014 09:42 AM
    "Can  i get a officialy report for this thing from Aruba ? i need explain to User with Report. Can you help me?"
    Please download the current IAP Users Guide (6.3.1.1-4.0) from the support site.  Refer to Ch. 33-IAP Management.  There is a table on page 305 describing the required version of code on the controller.
  • 15.  RE: My wireless controller 3.4.1..0 OS cannot discover Instant AP 105 os 6.1.2.
    Posted Nov 28, 2013 01:21 AM
    it is ok? when in different os?
