n type AP not broadcasting g-Ht
  • 1.  n type AP not broadcasting g-Ht
    Posted Apr 08, 2013 07:59 AM
    hi ,
    As i had installed AP-121 but few of the APs are not broadcasting g-Ht band
    as the o/p of 1 ap-121 >sh ap bss-table
    bss                ess          s/p   ip            phy  type  ch/EIRP/max-EIRP  cur-cl  ap name                          in-t(s)  tot-t       mtu   acl-state  acl
    00:1a:1e:35:85:83  Guests      pc-1  10.191.1.2    g    ap    11/20.5/20.5      1       Bharti Grnd Flr in front of 101  0        1h:58m:48s  1500  -          6
    00:1a:1e:35:85:80  WIFI1       pc-1  10.191.1.2    g    ap    11/20.5/20.5      4       Bharti Grnd Flr in front of 101  0        1h:58m:49s  1500  -          1
    00:1a:1e:35:85:81  WIFI2       pc-1  10.191.1.2    g    ap    11/20.5/20.5      0       Bharti Grnd Flr in front of 101  0        1h:58m:49s  1500  -          1
  • 2.  RE: n type AP not broadcasting g-Ht
    Posted Apr 08, 2013 08:38 AM
    Can you run show wlan ht-ssid-profile and post the results?
  • 3.  RE: n type AP not broadcasting g-Ht
    Posted Apr 09, 2013 05:17 AM
    High-throughput SSID profile "Aruba_htssid_prof"
    Parameter                            Value
    High throughput enable (SSID)        Enabled
    40 MHz channel usage                 Enabled
    MPDU Aggregation                     Enabled
    Max transmitted A-MPDU size          65535 bytes
    Max received A-MPDU size             65535 bytes
    Min MPDU start spacing               8 usec
    Supported MCS set                    0-15
    Short guard interval in 40 MHz mode  Enabled
    Legacy stations                      Allowed
    Allow weak encryption                Disabled
  • 4.  RE: n type AP not broadcasting g-Ht
    Posted Apr 09, 2013 09:34 AM
    Check your 802.11g radio profile and make sure that "High throughput enable (radio)" is active.
    List all profiles:          show rf dot11g-radio-profile
    View profile:               show rf dot11g-radio-profile DOT11G-RADIO-PROFILE-B
    802.11g radio profile "DOT11G-RADIO-PROFILE-B"
    Parameter                                      Value
    Radio enable                                   Enabled
    Mode                                           ap-mode
    High throughput enable (radio)                 Enabled
    Channel                                        N/A
    Transmit EIRP                                  15 dBm
    Non-Wi-Fi Interference Immunity                2
    Enable CSA                                     Disabled
    CSA Count                                      4
    Spectrum Monitoring                            Enabled
    Spectrum Monitoring Profile                    default-g
    Advertise 802.11d and 802.11h Capabilities     Disabled
    Spectrum Load Balancing                        Disabled
    Spectrum Load Balancing Mode                   channel
    Spectrum Load Balancing Update Interval (sec)  30 seconds
    Spectrum Load Balancing Threshold (%)          20 percent
    Spectrum Load Balancing Domain                 N/A
    Beacon Period                                  100 msec
    Beacon Regulate                                Disabled
    Advertized regulatory max EIRP                 0
    ARM/WIDS Override                              OFF
    Reduce Cell Size (Rx Sensitivity)              0 dB
    Management Frame Throttle interval             1 sec
    Management Frame Throttle Limit                20
    Maximum Distance                               0 meters
    RX Sensitivity Threshold                       0 dB
    RX Sensitivity Tuning Based Channel Reuse      disable
    Protection for 802.11b Clients                 Enabled
    Adaptive Radio Management (ARM) Profile        ARM-G-PROFILE-B
    High-throughput Radio Profile                  default-g
    AM Scanning Profile                            default
  • 5.  RE: n type AP not broadcasting g-Ht
    Posted Apr 10, 2013 03:40 AM
    802.11g radio profile "Bharti 101"
    Parameter                                   Value
    Mode                                        ap-mode
    Channel                                     N/A
    Transmit EIRP                               51 dBm
    Spectrum load balancing                     Disabled
    Spectrum Load Balancing domain              N/A
    RX Sensitivity Threshold                    0 -dBm
    Non 802.11 Interference Immunity            Level-2
    Enable CSA                                  Disabled
    CSA Count                                   4
    ARM/WIDS Override                           Disabled
    Adaptive Radio Management (ARM) Profile     default
  • 6.  RE: n type AP not broadcasting g-Ht
    Posted Apr 10, 2013 03:41 AM
    the ht is enabled even though not broadcastin g-ht
  • 7.  RE: n type AP not broadcasting g-Ht
    Posted Apr 10, 2013 06:42 AM
    What kind of encryption are you using?
  • 8.  RE: n type AP not broadcasting g-Ht
    Posted Apr 11, 2013 01:19 AM
    WPA 2 enterprice Authentication
    AES encryption
    with a security certificate
  • 9.  RE: n type AP not broadcasting g-Ht
    Posted Apr 13, 2013 10:56 AM
    Vikas,
    You should try recreating a parallel SSID with the WLAN/LAN Wizard from scratch to ensure that everything is configured properly.
