n(20Mhz) vs ac(20Mhz)
  • 1.  n(20Mhz) vs ac(20Mhz)
    Posted Jan 31, 2016 10:04 PM
    I've got a couple APs that are showing n(20Mhz) instead of ac. Just wondering where I could find the setting that would be causing this...? I changed some others by adding HT support on the radio profile, but these APs already have that enabled.
  • 2.  RE: n(20Mhz) vs ac(20Mhz)
    Posted Feb 01, 2016 01:34 AM
    EDIT: **Sorry I missed the 'some' part of the question**
    Joey,
    You removed the headers from the table, but you can see that the 2.4GHz channels (1, 6, 11) all show up as n(20), and the 5 GHz channels (36 an higher) show up as ac(20).
    n in the table stands for the 802.11n standard and indicates High Throughput (HT)
    ac stands for the 802.11ac standard which uses Very High Throughput (VHT), however on 5 GHz only.
    802.11ac is a 5 GHz only standard, so the 5 GHz radio is 11ac, where the radio on 2.4 GHz is using 11n.
    This is expected behavior. You can run ac(40) or ac(80) with 40 or 80 MHz channels, however that is only advised in an environment with very few AP's to avoid interference between different AP's.
  • 3.  RE: n(20Mhz) vs ac(20Mhz)
    Posted Feb 01, 2016 01:43 AM
    What can help you to find the source of configuration is the show ap profile-usage command:
    (Aruba7005) #show ap profile-usage ap-name AP225-23:28
    AP "AP225-23:28" Profiles
    Profile Type                         Profile                            Source
    AP system profile                    leds-diabled                       ap-name "AP225-23:28" ap-system-profile
    Regulatory Domain profile            5g-only-low                        ap-group "HomeLab" regulatory-domain-profile
    RF Optimization Profile              default                            ap-group "HomeLab" rf-optimization-profile
    RF Event Thresholds Profile          default                            ap-group "HomeLab" event-thresholds-profile
    AP group                             HomeLab
    AP name                              AP225-23:28
    AP "AP225-23:28" Radio 0 Profiles
    802.11a radio profile                    homelab-a    ap-group "HomeLab" dot11a-radio-profile
    Adaptive Radio Management (ARM) profile  min-15-nocm  rf dot11a-radio-profile "homelab-a" arm-profile
    High-throughput radio profile            default-a    rf dot11a-radio-profile "homelab-a" ht-radio-profile
    Spectrum profile                         default-a    rf dot11a-radio-profile "homelab-a" spectrum-profile
    AM Scanning profile                      default      rf dot11a-radio-profile "homelab-a" am-scan-profile
    (output above cleaned up a bit to improve readability)
    Then most specific have a look at the Radio 0 Profiles; and the difference between those AP's. Ther might be a AP specific configuration that disabled VHT on some of the AP's.
    Herman
