NAC and Cisco 3750
  • 1.  NAC and Cisco 3750
    Posted Nov 22, 2013 09:36 AM
    All,
    We are having issues with the clearpass portal page redirect when using wired-authentication.  When we plug in a PC to the switchport and open a browser we don't get a redirect to the clearpass portal page.  If I manually type in the redirect, i can get to the page fine.  I figure if I pop a browser it should take me there automatically.  Any suggestions are appreciated.
    Bill
  • 2.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 10:31 AM
    Can you share the Enforcement Profile you are sending back to the switch?   Specifically the Cisco-AVPair response attributes.
    Also, make sure you have http and https enabled on the switch:
    ip http server
    ip http secure-server
  • 3.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 10:59 AM
    Hi clembo,
    ip http server and ip http secure-server are in the switch config.
    Here's the enforcement profile we are sending back.
    1.Radius:CiscoCisco-AVPair=url-redirect=https://x.x.x.x/guest/poc_wired_login.php?mac=%{Connection:Client-Mac-Address-Colon}
    2.Radius:CiscoCisco-AVPair=url-redirect-acl=CPG
  • 4.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 11:06 AM
    Does Access Tracker show the proper RADIUS response and attributes returned on the Output tab?
    What does the following show for the port you are plugged into.  Does it show the proper URL Redirect and ACL?
    show authentication sessions interface <interface>
    Also, what does your CPG ACL look like?
  • 5.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 11:08 AM
    One more thing, what IOS version is on the switch?
  • 6.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 11:21 AM
    Here's the IOS version.
    Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE8,        RELEASE SOFTWARE (fc2)
  • 7.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 11:23 AM
    CPG ACL is below.  The 10.1.1.1 being the clearpass IP.
    ip access-list extended CPG
     deny   tcp any host 216.68.1.100
     deny   tcp any host 216.68.2.100
     deny   tcp any host 10.1.1.1
     deny   tcp any host 10.2.2.2
     permit tcp any any
    I will get you the access tracker and sh auth sessions info here shortly.
  • 8.  RE: NAC and Cisco 3750
    Posted Nov 22, 2013 02:08 PM
    Access Tracker info:
    Enforcement Profiles:
    POC Cisco redirect
    System Posture Status:
    UNKNOWN (100)
    Audit Posture Status:
    UNKNOWN (100)
    -RADIUS Response
    Radius:Cisco:Cisco-AVPairurl-redirect-acl=CPG
    Radius:Cisco:Cisco-AVPairurl-redirect=https://10.1.1.1/guest/poc_wired_login.php?mac=00:18:8b:b9:0c:bb
    dtnsa-5-lab-9#sh authentication sessions int g1/0/12
                Interface:  GigabitEthernet1/0/12
              MAC Address:  0018.8bb9.0cbb
               IP Address:  10.237.75.46
                User-Name:  00188bb90cbb
                   Status:  Authz Success
                   Domain:  DATA
           Oper host mode:  multi-auth
         Oper control dir:  both
            Authorized By:  Authentication Server
               Vlan Group:  N/A
             URL Redirect:  https://10.1.1.1/guest/poc_wired_login.php?mac=00:18:8b:b9:0c:bb
         URL Redirect ACL:  CPG
          Session timeout:  N/A
             Idle timeout:  N/A
        Common Session ID:  0AC700E60000002333D9E98D
          Acct Session ID:  0x0000003E
                   Handle:  0x35000023
    Runnable methods list:
           Method   State
           dot1x    Failed over
           mab      Authc Success
  • 9.  RE: NAC and Cisco 3750
    Posted Nov 23, 2013 09:04 AM
    I don't see anything obvious with your results.   It looks like ClearPass is sending the proper attributes and the switch is setting them for hte port.   Can you show the configuration for the port itself please?
  • 10.  RE: NAC and Cisco 3750
    Posted Nov 24, 2013 06:04 AM
    Try this link.
    https://afp.arubanetworks.com/afp/index.php/Cisco_Wired_Guest_for_ClearPass_6.2.1_and_greater
    there are a couple verification commands in the trouble shooting area and I added some on the bottom for DACLs that will help you trouble your config
    aaa new-model
    aaa authentication dot1x default group radius local
    aaa authorization network default local group radius
    aaa authorization auth-proxy default group radius
    aaa accounting dot1x default start-stop group radius
    aaa server radius dynamic-author
     client 10.80.2.100 server-key XXXXXXXX
     client 10.80.2.106 server-key XXXXXXXX
     client 10.80.2.107 server-key XXXXXXXX
     port 3799
     auth-type all
    interface FastEthernet1/0/18
     switchport access vlan 200
     switchport mode access
     switchport voice vlan 50
     authentication event no-response action authorize vlan 400
     authentication host-mode multi-auth
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication periodic
     authentication timer reauthenticate server
     mab
     dot1x pae authenticator
     dot1x timeout tx-period 20
     dot1x timeout supp-timeout 20
     dot1x max-reauth-req 1
     no mdix auto
     spanning-tree portfast trunk
    interface GigabitEthernet1/0/1
    interface GigabitEthernet1/0/2
    interface Vlan1
     ip address 10.80.2.5 255.255.255.0
     ip helper-address 10.80.2.254
     ip helper-address 10.80.2.100
     no ip route-cache
     no ip mroute-cache
    interface Vlan400
     description "quarantine_vlan"
     ip address 10.0.4.5 255.255.255.0
     no ip route-cache
     no ip mroute-cache
     shutdown
    ip default-gateway 10.80.2.1
    ip classless
    ip http server
    ip access-list extended cplab
     deny   tcp any host 10.80.2.100
     permit tcp any any
    ip access-list extended default_acl
     permit ip any any
    ip access-list extended guest
     deny   tcp any host 10.80.2.106
     deny   tcp any host 10.80.2.107
     permit tcp any any
  • 11.  RE: NAC and Cisco 3750
    Posted Dec 31, 2013 05:31 AM
    Hello guys, I have similar problem with wired web-auth (as decribed here), but the link you provided "https://afp.arubanetworks.com/afp/index.php/Cisco_Wired_Guest_for_ClearPass_6.2.1_and_greater" requires authorization
    Which credentials should I use in order to open it?
    thanks
  • 12.  RE: NAC and Cisco 3750
    Posted Dec 31, 2013 06:16 AM
    You will need to set up a partner account.
    https://arubanetworkskb.secure.force.com/prm/
  • 13.  RE: NAC and Cisco 3750
    Posted Jan 11, 2014 06:14 AM
    I did everything as described there (https://arubanetworkskb.secure.force.com/prm/), everything works fine, but I have some trouble with Guest application iteraction: when guest expires, there is no feedback from Guest App (i.e. no PoD/CoA sent to switch => sessions remain active even with expired account) while if I do manual "disconnect" from Guest->Active sessions - it works.
    In order to make username "visible" for Guest App, I did one trick (described here: https://afp.arubanetworks.com/afp/index.php/How-To:_Return_username_for_MAC_Auth), therefore now Guest App is aware of username of the session, but still no action is performed during account expiration.
    In attachement - export of 2 services, needed for centralized web-auth (.xml)
    What did I do wrong?
    Thanks in advance
  • 14.  RE: NAC and Cisco 3750
    Posted Jan 12, 2014 01:18 AM
    Alex,
    Can you re-add the link of the guide you followed. The link you provided just takes you to the login page.
    Just a couple things.
    1. What version of CPPM
    2. Switch Model, and FIrmware
    2. Is insight enabled
    3. Under Administration » Server Manager » Server Configuration. Click on the server, go to service parameters, Radius, and scroll to     the bottom and make sure accounting is set to true.
  • 15.  RE: NAC and Cisco 3750
    Posted Jan 12, 2014 07:24 AM
    Sorry, I gave wrong link, here is correct:
    CPPM - 6.2.4
    switch - catalyst 3750-x IOS 12.2(55)SE3
    Insight - enabled, though I don't use this database in my case (I use endpoint repository - for MAB, guest DB - for Web auth)
    Radius accounting - enabled
  • 16.  RE: NAC and Cisco 3750
    Posted Jan 14, 2014 04:18 PM
    Guys, this task is very important for me (I'm doing R&D about ClearPass for one big company),
    Any suggestion about ?
  • 17.  RE: NAC and Cisco 3750
    Posted Jan 14, 2014 04:22 PM
    Alex,
    I'm traveling at the moment and haven't had time to look at your issue. Can you send me a private message with your contact info and I will have a CP se contact you
  • 18.  RE: NAC and Cisco 3750
    Posted Nov 25, 2013 07:57 AM
    Here's the config of the port itself.
    interface GigabitEthernet1/0/12
     switchport access vlan 75
     ip access-group default in
     mab
     dot1x timeout tx-period 3
     dot1x timeout supp-timeout 5
    end
  • 19.  RE: NAC and Cisco 3750
    Posted Dec 10, 2013 07:00 PM
    What type of portal page are you using for this? I was able to "guest self register" but how to make it authenticate with AD?
  • 20.  RE: NAC and Cisco 3750
    Posted Jan 14, 2014 09:02 PM
    Alex,
    In your mac-auth enforcement profile. What do you have set for the session-timer. This should be a variable in the number of seconds you want client to re-auth. All based on when the guests account expires.
    This is another authentication source that you would use as an authorization source. To calculate time remaining on clients device.
    Does this sound correct?
  • 21.  RE: NAC and Cisco 3750
    Posted Jan 15, 2014 02:50 AM
    I have set session timeout for 30 min (static value) - as possible workaround, since it's impossible to extract %{remailning time} for Guest account from Endpoint database (I use it for MAB) - there is no such field there.
    Even if I add Guest DB as authentication/authorization source for MAB service, and use [Post Auth profiles] - no result, logs from access tracer show: "Failed to get these values"
    Remaining time - is good idea, hovewer, this is also static value (computed at the moment of guest login), and I need some explicit dynamic mechanism (like CoA) - for example, when you change expiration time for account while session is active, and so on.
  • 22.  RE: NAC and Cisco 3750
    Posted Jan 15, 2014 06:04 AM
    In the supplied link from tarnold - how is the computer placed in the Computer role?
    There is some holes in there that mess things up for me so any clarification for all the points would be awsome.
  • 23.  RE: NAC and Cisco 3750
    Posted Jan 15, 2014 06:36 AM
    I don't use such role in my case. CPPM returns redirect-url + redirect ACL on MAB failure, otherwise (Endpoint = known) - simple allow policy.
    Classification is OK
    I attached screenshots for used services (MAB+WEB)
  • 24.  RE: NAC and Cisco 3750
    Posted Jan 15, 2014 06:46 AM
    Could you also post the summary pages for the Services used?
  • 25.  RE: NAC and Cisco 3750
    Posted Jan 15, 2014 06:53 AM
    here they are
  • 26.  RE: NAC and Cisco 3750
    Posted Jan 15, 2014 08:35 AM
    Alex,
    You have to set-up an authorization service that runs an SQL query against the  tips_guest_users database. like the one seen below then from here you would use something like this in the value of the enforment policy
    %{Authorization:[MAC-Guest-Check]:RemainingExpiration}
    auth source name "MAC-Guest-Check"
    SELECT user_id as guest_device_user , CASE WHEN enabled = FALSE THEN 225 WHEN
    ((start_time > now()) OR ((expire_time is not null) AND (expire_time <=
    now()))) THEN 226 WHEN approval_status != 'Approved' THEN 227 ELSE 0 END AS
    Account_Status, sponsor_name, CAST(EXTRACT(epoch FROM (expire_time - NOW())) AS
    INTEGER) AS remaining_expiration FROM tips_guest_users WHERE ((guest_type =
    'USER') AND (user_id = '%{Endpoint:Username}') AND (app_name != 'Onboard') AND
    (enabled = 't') AND ((expire_time is null) OR (expire_time >
    CURRENT_TIMESTAMP)))
    * this is from a CPPM Guest template.
    if you extended the time of the user they would just reauthenticate. if you shorten the account time the device would have to be COA somehow to get the new timeout value.
  • 27.  RE: NAC and Cisco 3750
    Posted Jan 16, 2014 07:37 AM
    Thanks a lot for your reply, but unfortunately, I'm not familiar with SQL
    I have found, that my Catalyst 3750-x  IOS 12.2(55)SE3, processed URL-redirect attribute incorrectly (didn't append "mac=..." part)
    I changed IOS code verison to 15.2, now url-redirect works OK, but this hasn't solved the problem, even more - now I see several active sessions (as MAB and as username), automatic disconnect (at expiration time) doesn't work
    I tried to use different MAC format in redirect-url (.php?mac=%{----   Colon/Dot/NoDelim/Hyphen}), but still no result
    In attachement - output from Guest->actie sessions
    Here is log output from access-tracer (web-auth service):
    Request log details for session: W00000029-01-52d7baae
    Time Message
    2014-01-16 12:55:42,959[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-645 h=79 r=W00000029-01-52d7baae] INFO Core.ServiceReqHandler - Service classification result = Cisco WEB guest policy
    2014-01-16 12:55:42,979[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO TAT.TagAttrTableUtil - buildTagAttrTableInput: Connection:NAD-IP-Address is not found
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO Common.EndpointTable - Returning EndpointSPtr for macAddr 001560bc07a8
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO Common.GuestUserTable - Returning GuestUserSPtr for user ID asd@asd.com
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO Common.TagDefinitionCacheTable - No TagDefCacheMap could be found for instance id = 0 entity id = 29
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] WARN Common.TagDefinitionCacheTable - Failed to build TagDefinitionMap. Unknown NadClient for Id=0
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO TAT.TagAttrHolderBuilder - No tags built for instanceId=0|entity=Device
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO TAT.AluTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL AuthLocalUser)
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 r=psauto-1389430421-646 h=83 r=W00000029-01-52d7baae] INFO TAT.OnboardTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Onboard Device User)
    2014-01-16 12:55:42,980[RequestHandler-1-0x7fe522df6700 h=4267 c=W00000029-01-52d7baae] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_SOAP_WEBAUTH Started ***
    2014-01-16 12:55:42,981[RequestHandler-1-0x7fe522df6700 h=4268 c=W00000029-01-52d7baae] WARN REC.EvaluatorCtx - Prerequisites set is empty, not populating the Request Map
    2014-01-16 12:55:42,983[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4269 c=W00000029-01-52d7baae] INFO Common.GuestUserTable - Returning GuestUserSPtr for user ID asd@asd.com
    2014-01-16 12:55:42,983[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4269 c=W00000029-01-52d7baae] INFO Core.PETaskRoleMapping - Roles: Guest], User Authenticated]
    2014-01-16 12:55:42,986[RequestHandler-1-0x7fe522df6700 h=4272 c=W00000029-01-52d7baae] INFO Core.PETaskEnforcement - EnfProfiles: Guest MAC Caching, Guest Session Limit, Guest Do Expire, Guest Expire Post Login, Cisco - Terminate Session]
    2014-01-16 12:55:42,987[RequestHandler-1-0x7fe522df6700 h=4277 c=W00000029-01-52d7baae] INFO Core.PETaskGenericEnfProfileBuilder - getApplicableProfiles: No App enforcement (Generic) profiles applicable for this device
    2014-01-16 12:55:42,988[RequestHandler-1-0x7fe522df6700 h=4273 c=W00000029-01-52d7baae] ERROR Common.AppEnfProfileTable - getAppType: Failed for id=3005
    2014-01-16 12:55:42,988[RequestHandler-1-0x7fe522df6700 h=4273 c=W00000029-01-52d7baae] ERROR Common.AppEnfProfileCacheTable -
    2014-01-16 12:55:42,988[RequestHandler-1-0x7fe522df6700 h=4273 c=W00000029-01-52d7baae] ERROR Common.AppEnfProfileTable - getAppType: Failed for id=3006
    2014-01-16 12:55:42,988[RequestHandler-1-0x7fe522df6700 h=4273 c=W00000029-01-52d7baae] ERROR Common.AppEnfProfileTable - getAppType: Failed for id=3003
    2014-01-16 12:55:42,988[RequestHandler-1-0x7fe522df6700 h=4273 c=W00000029-01-52d7baae] ERROR Common.AppEnfProfileTable - getAppType: Failed for id=3004
    2014-01-16 12:55:42,989[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4275 c=W00000029-01-52d7baae] INFO Core.PETaskRadiusCoAEnfProfileBuilder - Radius_CoA enfProfiles used: Cisco - Terminate Session]
    2014-01-16 12:55:42,989[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4275 c=W00000029-01-52d7baae] INFO Core.PETaskRadiusCoAEnfProfileBuilder - UnknownAutzParams to fetch for RadiusCoAEnfProfiles: :
    2014-01-16 12:55:42,989[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4275 c=W00000029-01-52d7baae] INFO Core.PETaskRadiusCoAEnfProfileBuilder - UnknownNAutzParams to fetch for RadiusCoAEnfProfiles: : Radius:IETF:Calling-Station-Id
    2014-01-16 12:55:42,989[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4275 c=W00000029-01-52d7baae] WARN Util.ParameterizedString - getReplacedStrings: Failed to replace parameString =%{Radius:IETF:Calling-Station-Id}, error=No values for param=Radius:IETF:Calling-Station-Id
    2014-01-16 12:55:42,990[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4275 c=W00000029-01-52d7baae] ERROR Core.PETaskRadiusCoAEnfProfileBuilder - addParamsFromParameterizedProfile: Failed to find finalValue for name= Radius:IETF:Calling-Station-Id value = %{Radius:IETF:Calling-Station-Id}. Searching attributes from battery
    2014-01-16 12:55:42,990[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4276 c=W00000029-01-52d7baae] INFO Core.PETaskPostAuthEnfProfileBuilder - Post auth enforcement profiles used: Guest MAC Caching, Guest Session Limit, Guest Do Expire, Guest Expire Post Login
    2014-01-16 12:55:42,990[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4276 c=W00000029-01-52d7baae] INFO Core.PETaskPostAuthEnfProfileBuilder - UnknownAutzParams to fetch for PostAuthEnfProfiles: :
    2014-01-16 12:55:42,990[RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4276 c=W00000029-01-52d7baae] INFO Core.PETaskPostAuthEnfProfileBuilder - UnknownNAutzParams to fetch for PostAuthEnfProfiles: :
    2014-01-16 12:55:42,997[RequestHandler-1-0x7fe522df6700 h=4278 c=W00000029-01-52d7baae] INFO Core.PETaskCliEnforcement - startHandler: No commands for CLI enforcement
    2014-01-16 12:55:43,007[RequestHandler-1-0x7fe522df6700 h=4280 c=W00000029-01-52d7baae] INFO Core.PolicyResCollector - getSohr: Failed to generate Sohr
    2014-01-16 12:55:43,010[RequestHandler-1-0x7fe522df6700 h=4279 c=W00000029-01-52d7baae] INFO Core.PolicyResCollector - getSohr: Failed to generate Sohr
    [RequestHandler-1-0x7fe522df6700 r=W00000029-01-52d7baae h=4267 c=W00000029-01-52d7baae] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_SOAP_WEBAUTH Completed ***
