NAC with 2520 switch
  • 1.  NAC with 2520 switch
    Posted Jun 11, 2018 08:37 AM
    Hi All,
        I am trying to setup port security between Clearpass and a 2520 device. I believe everything is setup OK but there is nothing showing in access tracker or venet viewer. This is a brand new CPPM and I've setup this on the switch -
    radius-server host 10.x.x.x key "secretkey"
    radius-server host 10.x.x.x dyn-authorization
    aaa accounting update periodic 3
    aaa accounting system start-stop radius
    aaa authentication port-access eap-radius
    aaa port-access authenticator 2
    aaa port-access authenticator 2 client-limit 3
    aaa port-access authenticator active
    aaa port-access mac-based 2
    aaa port-access mac-based 2 addr-limit 3
    But the show port-access authenticator clients command just shows the client status as "connecting"
    The CPPM is pingable from the switch and vice-versa.
    Any ideas
  • 2.  RE: NAC with 2520 switch
    Posted Jun 11, 2018 08:57 AM
    OK so it looks like the requests are arriving at another configured server. Is there any way to point the requests to CPPM on a per-port basis? or some other workaround.
  • 3.  RE: NAC with 2520 switch
    Posted Jun 11, 2018 11:59 AM
    Please check the event viewer if you have an error in the shared secret or if the NAD is not configured in CPPM. As this is a new installation you might have missed something.
