NAP with Clearpass - Client IP isn't being sent to clearpass
  • 1.  NAP with Clearpass - Client IP isn't being sent to clearpass
    Posted Jun 14, 2013 06:05 PM
    I'm hoping someone else has come across this before.  I have CPPM 6.1 and have wired and wireless clients authenticating against active directory.
    When I try and integrate NAP into the setup, I receive the error below
    No credentials received for Radius posture server=NAP Test
    I've enabled NAP in DHCP and in NPS.  I'd been using the NPS for my 802.1x authentication prior to purchasing CPPM.  If anyone has come across this, I'd really appreciate any pointers you have.  I have the service started on the client machines and the settings are being pushed out via a GPO.
    Robert
  • 2.  RE: NAP with Clearpass - Client IP isn't being sent to clearpass
    Posted Jun 14, 2013 07:26 PM
    Hello Robert
    Can you explain me better your setup?
    Who is the radius server? it is the CPPM?
    If its the clearpass policy manager
    What is your config?
    Did you join the CPPM to the domain?
    Who is your CA? it is the CPPM or do you have a windows pki Infraestructure which is acting as CA? or you bought a certificate?
    We are poor information to help you or at least i do.
    Cheers
    Carlos
  • 3.  RE: NAP with Clearpass - Client IP isn't being sent to clearpass
    Posted Jul 02, 2013 10:23 AM
    Sorry this took so long.  I was pulled into another project.
    I'm using a clearpass for the radius server and I have joined the CPPM to the domain.  We have a Windows PKI infrastructure and I've added the certificates to the CPPM.  CPPM also has a certificate we bought so that guest users aren't prompted to install a certificate.
    I've searched for documentation for how to add NAP to an external device.  Am I correct that CPPM should act as the authenticator between the Windows devices and the authentication server and that CPPM will then query the MS server running NAP for posture information?
    The way it's setup now is
    Client -> Switch/Controller (my CPPM is set as the RADIUS server) ->CPPM (authenticates the client via either mac auth or an AD lookup depending on the type of device) ->NAP (setup in CPPM as a posture server.)
    I hope this makes more sense.  If you or anyone has any suggestions or questions, I'll be sure to answer them quickly.
    Robert
  • 4.  RE: NAP with Clearpass - Client IP isn't being sent to clearpass
    Posted Jul 05, 2017 12:56 PM
    Hi, did you figure this out?
  • 5.  RE: NAP with Clearpass - Client IP isn't being sent to clearpass
    Posted Jul 05, 2017 01:45 PM
    Please start a new thread. This one is 4 years old.
