NAT Vlan on controller
  • 1.  NAT Vlan on controller
    Posted Mar 03, 2016 10:38 AM
    I'm experiencing a problem of NATing for one of my Vlan on my controller :
    I have 2 Vlans : - Vlan 10 which is my default Vlan
    - Vlan 33 which is only declared on my controller (and not on the rest of the network)
    I'd like to NAT the IP coming from my Vlan 10 to the Vlan 33. I'have already enabled the NAT on the Vlan 33 and I have my default gateway on my Vlan 10.
    When i'm am in my Vlan 33 and I want to ping an IP address of my Vlan 10 : The ping goes through the controller, reaches the IP address, goes back to the controller, and get lost. So I can communicate in only one way.
    In CLI :
    Spoiler
    interface vlan 10
    ip address 192.168.10.210 255.255.255.0
    no ip routing
    interface vlan 33
    ip address 172.16.33.1 255.255.255.0
    no ip routing
    ip nat inside
    ip default-gateway 192.168.10.254
    Any help most welcomed.
    Cheers.
  • 2.  RE: NAT Vlan on controller
    Posted Mar 03, 2016 11:11 AM
    Does the controller have an ip address in VLAN 33?  Is that the default gateway of your clients?  IP nat inside only works for traffic leaving the controller, not between vlans, really....unless I am wrong...
    EDIT:  Hold on, why do you have "no ip routing" on your VLANs?  That means that the controller default gateway cannot route any traffic...
  • 3.  RE: NAT Vlan on controller
    Posted Mar 03, 2016 11:24 AM
    You need to allow ip routing under those layer 3 VLANS otherwise you won't be able to route
    Sent from Outlook for iPhone
  • 4.  RE: NAT Vlan on controller
    Posted Mar 03, 2016 11:37 AM
    Does the controller have an ip address in VLAN 33? Yes, as I wrote previously, it’s 172.16.33.1
    Is that the default gateway of your clients?  Yes, it’s default gateway for VLAN 33 users
    IP nat inside only works for traffic leaving the controller : So how does users get a response for dns request, ping,… ?
     Hold on, why do you have "no ip routing" on your VLANs?  Because the controller doesn’t do intervlan routing, it’s done by our network core
    I tried to activate ip routing on both interface (VLAN 1 and 33) but no way to access to the network !
    I activated the source NAT. Are there any other operations to do ? Do I have to activate the NAT pools for example ?
  • 5.  RE: NAT Vlan on controller
    Posted Mar 03, 2016 11:49 AM
    What are you trying to do?  It is not clear.
  • 6.  RE: NAT Vlan on controller
    Posted Mar 03, 2016 12:00 PM
    We have a Guest VLAN (VLAN 33), which is only on the Wifi controller.
    We want to allow the users of this VLAN to access to the Internet. To do so, we activated source nat for VLAN 33 users. But we don't manage to make it works.
  • 7.  RE: NAT Vlan on controller
    Posted Mar 03, 2016 12:33 PM
    1.  The client default gateway must be the controller's ip address on VLAN 343
    2.  You must remove "no ip routing"
    3.  You must enable "source nat" or "ip nat inside" on VLAN 33
    4.  The client traffic will be source-natted out of the controller's uplink by default.
    5.  Client traffic will appear to be coming out of the management ip address of the controller.
  • 8.  RE: NAT Vlan on controller
    Posted Mar 04, 2016 03:56 AM
    Well, we already tried this configuration : our requests are nated but we don't get the response of it.
    I agree with you that it should work but it doesn't. I made the configuration again and again, beginning from nothing, and I'm still having the same problem. I can only ping the interfaces of my controller (which is logic !)
    Do you know some commands to see if the NAT is well working ?
  • 9.  RE: NAT Vlan on controller
    Posted Mar 04, 2016 04:53 AM
    You should be able to see it running: show datapath session table
    Regards
    Borja
  • 10.  RE: NAT Vlan on controller
    Posted Mar 04, 2016 07:59 AM
    Well you should open a case with TAC so that they can look at your toplogy and configuration.  OR you should simplify things because we all have the most basic version of this working in our labs (private subnet, ip nat inside, nat working).  You also should check to make sure that you do not have an ACL on an interface that is blocking traffic.  Like was mentioned, "show datapath session table <ip address of client>" is probably the best troubleshooting tool to understand if somethig is being blocked or not.
  • 11.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 03:42 PM
    Hi there,
    I have a similar case. IP routing is enabled.
    I am trying to use NAT in order to give Internet access (directly from the vlan controller) to the users of two different SSIDs but is not working.
    The configuration is as follows:
    ip access-list eth validuserethacl
    permit any
    ip access-list session validuser
    network 169.254.0.0 255.255.0.0 any any deny
    network 127.0.0.0 255.0.0.0 any any deny
    network 224.0.0.0 240.0.0.0 any any deny
    host 255.255.255.255 any any deny
    network 240.0.0.0 240.0.0.0 any any deny
    any any any permit
    ipv6 host fe80:: any any deny
    ipv6 network fc00::/7 any any permit
    ipv6 network fe80::/64 any any permit
    ipv6 alias ipv6-reserved-range any any deny
    ipv6 any any any permit
    vlan 1
    vlan 4
    vlan 5
    vlan 999
    interface gigabitethernet 1/0
    description "G1/0 - NAT INSIDE - LAG 1"
    no trusted vlan 999
    interface gigabitethernet 1/1
    description "GE1/1 - NAT INSIDE - LAG 1"
    no trusted vlan 999
    interface gigabitethernet 1/2
    description "GE1/2 - NAT INSIDE - LAG 1"
    lacp group 1 mode active
    no trusted vlan 999
    interface gigabitethernet 1/3
    description "GE1/3 - NAT OUTSIDE"
    no trusted vlan 1-4094
    no trusted
    switchport mode access
    switchport access vlan 999
    ip access-group validuserethacl in
    ip access-group validuserethacl out
    ip access-group validuser session
    controller-ip vlan 1
    interface vlan 1
    ip address 10.10.40.1 255.255.255.0
    interface vlan 4
    ip address 10.10.70.1 255.255.255.0
    ip nat inside
    ip helper-address 172.21.10.173
    interface vlan 5
    ip address 10.10.50.1 255.255.255.0
    ip nat inside
    interface vlan 999
    ip address w.x.y.z 255.255.255.0
    ip nat outside
    ip default-gateway w.x.y.a
    ip route 172.21.28.0 255.255.255.0 172.21.19.1
    ip route 172.21.10.0 255.255.255.0 172.21.19.1
    ip route 172.21.16.0 255.255.255.0 172.21.19.1
    ip route 172.21.25.0 255.255.255.0 172.21.19.1
    ip route 10.120.1.0 255.255.255.0 172.21.19.1
    The role used ti test thos by the WLAN users (using vlans 4 and 5) is the standard "authenticated" role with the allowall access list.
    I am thinking that NAT is not working since some internal networks (the ones with suobnet 172.21.x.0/24) use public address space instead of the 172.16.x.o/24 private address space and interact with the WLAN networks that use 10.10.n.0/24 networks.
    When I am saying the nat is not working I mean that a user connected to the SSIDs related to vlan 4 or vlan 5 cannot reach the internet (we are testing with WIndows 10).
    Also I can ping the ip address w.x.y.z/24 assigned to  the interface vlan 999  but I cannot ping the default gateway declared on the controller to get acces to the internet(the w.x.y.a/24 IP address).
    Any guidance about this is more than welcome.
    Thanks in advance.
    Jose
  • 12.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 05:15 PM
    Jose,
    You might be making this more complicated than it needs to be.  Is VLAN 999 a public ip address?
  • 13.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 05:33 PM
    yes is a public IP address.
  • 14.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 05:52 PM
    Is the default gateway even pingable?
    What is the controller connected to, a cable modem?
    By the way Jose, you should open your own thread so that you do not step on what the person who originally opened this thread is trying to get answers for.
  • 15.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 06:02 PM
    Thanks Colin,
    The default gateway is pingable from the controller. The controller is connected to a LAN switch and this one to a router. The end customer has a range of public IP addresses  given by his ISP.
    Example
    interface vlan 999
     ip address 189.188.104.98 255.255.0
     ip nat outside
    ip default gateway 189.188.104.1
    Do you want me to opena  a new thread?
  • 16.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 06:07 PM
    Correction to the example:
    interface vlan 999
     ip address 189.188.104.98 255.255.255.0
     ip nat outside
  • 17.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 06:27 PM
    You should not have to do an ip nat outside.  As long as your controller can route/ping past the default gateway, user on a vlan that has ip nat inside should be able to do the same.
  • 18.  RE: NAT Vlan on controller
    Posted Sep 04, 2017 06:47 PM
    Thank you for the feedback Colin, I will test it tomorow and let you know.
