Necessary firewall rules between Access Point and Controller with directions
  • 1.  Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 01, 2016 08:00 AM
    Hi Airheads experts,
    Please help me to clear this topic. I need the exact firewall rules with directions between the APs and the controller. I search in Airheads, userguide and hardening guide as well but there are only a list of ports. I need in the following form. Forexample:
    scr: AP dst: controller service: DHCP
    scr: AP dst: controller service: PAPI
    scr: AP dst: controller service: FTP, TFTP
    scr: AP dst: controller service: GRE
    scr: AP dst: controller service: udp 4500
    or some policy is both direction etc.
    Thank you in advance for your reply!
    Zs
  • 2.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 01, 2016 09:11 AM
    Where are you applying this ACL? On the controller itself or on your firewall ?
  • 3.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 01, 2016 09:20 AM
    On the firewall.
  • 4.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 02, 2016 05:47 AM
    In that case I suggest you post the question in your firewall vendor's forum to get exact command syntax to implement what you are trying to do.
    This can also be implemented on the Aruba controller firewall if you need to, if you decide to use the controller firewall we can provide you the commands to allow those ports
  • 5.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 02, 2016 07:53 AM
    Hi Victor,
    I need the exact firewall rules in general schematic form. I am familiar with firewalls, thus I will be know the cli.
    So who start the communication this is important in an stateful operation. In ClearPass or AirWave guides there are a gorgeous table (please see the attached file) and I need like that and I think this is very useful for others as well (the ports is documented but the directions don't). So If someone can give me the following form I will be grateful.
    source: destination: service:
    Attachment(s)
    pdf
    airwave_portok2.pdf   606 KB 1 version
  • 6.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 02, 2016 09:53 AM
    Ohh I see , I think I misunderstood your initial request
    Here you go:
    http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Firewall_Port_Info.php
  • 7.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 02, 2016 11:30 AM
    Thank you Victor!
    If I see well the following ports and directions have to setup on the firewall, to the connection will be good. And it can be said that all of the following connections initiate from the AP itself.
    Please correct it if it is wrong.
    source: AP, destination: controller, service: DHCP
    source: AP, destination: controller, service: PAPI
    source: AP, destination: controller, service: FTP, TFTP
    source: AP, destination: controller, service: GRE
    source: AP, destination: controller, service: udp 4500
    source: AP, destination: controller, service: NTP
    source: AP, destination: controller, service: SYSLOG
    If I turn on the CPSEC do I need to allow ntp and syslog traffic or those are going through the IPSEC tunnel as well as the others?
    Thank you!
    Zs
  • 8.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 02, 2016 03:13 PM
    That's correct
  • 9.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted Mar 02, 2016 03:27 PM
    Thank you for your help and work!
    Br.,
    Zs
  • 10.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 12:28 PM
    Will this work if the a filter is applied on a switch port in which the AP connects?
    So for example, if an AP is connected to a Juniper switch (EX4300) and I apply a filter to only allow the required ports/protocols for communication between AP and controllers (master and LMS) will that work?
    Does the communication require a stateful connection? I will post the switch config momentarily.
    hlavender
  • 11.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 12:34 PM
    Now that I think about it...I guess it doesn't matter? TCP is connection oriented.
  • 12.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 02:03 PM
    Why don't you try it on a single port and let us know?
  • 13.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 09:48 PM
    Below if the firewall filter created on the Juniper switch. It is currently applied to just one switch port. When applied, the AP goes to a "down" status. Once removed, the AP comes back up. Not sure if anyone has tried this before and was successful? Added the multicast group as a last ditch effort.
    firewall {
    family ethernet-switching {
    filter WAP-in {
    term aruba-ap_udp {
    from {
    destination-port [ bootps dhcp tftp 8211 domain syslog 4500 ntp 53 ];
    ip-protocol udp;
    then accept;
    term aruba-ap_udp_s {
    from {
    source-port 8211;
    ip-protocol udp;
    then accept;
    term aruba-ap_tcp {
    from {
    destination-port ftp;
    ip-protocol tcp;
    then accept;
    term aruba-ap_gre {
    from {
    ip-protocol gre;
    then accept;
    term permit-ping {
    from {
    icmp-type [ echo-reply unreachable ];
    ip-protocol icmp;
    then accept;
    term permit-tcp_est {
    from {
    tcp-established;
    ip-protocol tcp;
    then accept;
    term aruba-adp {
    from {
    ip-destination-address {
    239.0.82.0/24;
    ip-protocol udp;
    then accept;
    term default-deny {
    then {
    discard;
    log;
    count WAP-denied;
    hlavender
  • 14.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 09:51 PM
    Just curious, why are you doing an ACL for the AP? The access points are hardened and traffic is tunneled back to the controller.
  • 15.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 09:54 PM
    The customer has requested for the ports to be locked down since the AP's will be in an untrusted or common area. It's actually a little more to it than just that but that's the request in a nutshell.
  • 16.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 09:57 PM
    Is the concern that someone would unplug the AP and connect another device?
  • 17.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 10:00 PM
    Yes.
  • 18.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 10:04 PM
    Basic 802.1X authentication solves that problem without the concern of using up all your ACE entries in the switch.
    If the AP were to be unplugged, the port would effectively reset and the next device that is plugged in would have to pass 802.1X or other authorization methods.
  • 19.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 12, 2016 10:12 PM
    Hhmmm, I didn't think about that. We have configured 802.1x currently on the wire so that may be an option.
    Otherwise, any thoughts on acl's on switchports? This may still be the way they would like to go.
  • 20.  RE: Necessary firewall rules between Access Point and Controller with directions
    Posted May 19, 2016 05:11 PM
    Issue resolved...for the most part.
    The AP, which is an AP-325 was getting stuck while attempting to upgrade the software. During a wireshark packet capture, it was determined that passive FTP was being used. Since this uses "random" ports, the firewall filter on the Juniper EX4300 needed to be tweaked to allow this.
    Made adjustments and now it works...the for most part bit was that additional ports are required for this to work. This would have been easier if this was passing through a firewall in flow mode or application layer firewall.
    Anyhoo.
    -hlavender
