Need Advice About Home Network
  • 1.  Need Advice About Home Network
    Posted Nov 08, 2023 05:56 AM
    Hi All,
    I want to create some strong WIFI network (MESH Network) on my home, it's 5 rooms based, 1 of the rooms is "mamad" room.
    I have optical fiber in my home, it's come to the living room, there I need some router to connect to ISP (PPPOE) and then put some AP in the home, and also in the living room.
    In the "mamad" room I need also AP (because there the WIFI signal is very low).
    Until now, I thought to put some ASUS XD6 2 pack with ASUS GT-AX6000 (in the "mamad").
    But I saw some recommendations about Aruba AP25 or AP22, and want to hear your advice.
    I know that the Aruba AP25 (or other model) not works as router (PPPOE) so I need some router before connect the APs.
    About the router, someone recommends me DrayTek 2865/2866, without WIFI, just to connect to ISP, if you have other recommendation, I love to hear.
    I really debating between AP25 and AP22. Here, AP22 costs 155USD while AP25 costs 266USD.
    But I also know that AP22 don't support 160MHz.
    Regards.
    *Managers, I really hope it's the best forum for my question.
  • 2.  RE: Need Advice About Home Network
    Posted Nov 08, 2023 11:15 AM
    Not sure if this is the right place for such a question as most people here are working on large enterprise deployments.
    As you are considering InstantON, the InstantON community may be a better starting point.
