Need AP's to obtain IP address from DHCP Server
  • 1.  Need AP's to obtain IP address from DHCP Server
    Posted Jan 17, 2015 03:02 PM
    I would like the AP's to obtain an IP address from our standard DHCP server that serves or pc's. Do I need to make changes to the AP's config? What are the steps that the AP takes in looking for a DHCP server?
  • 2.  RE: Need AP's to obtain IP address from DHCP Server
    Posted Jan 17, 2015 03:20 PM
    APs default to DHCP out of the box. Are wired clients in the same VLAN getting an address?
  • 3.  RE: Need AP's to obtain IP address from DHCP Server
    Posted Jan 17, 2015 03:39 PM
    Yes, they are on the same subnet.
    Sent from my Verizon Wireless 4G LTE smartphone
  • 4.  RE: Need AP's to obtain IP address from DHCP Server
    Posted Jan 17, 2015 03:21 PM
    By default Aruba APs obtain their IP from DHCP. The AP will follow the normal process any other device would to request a DHCP address. Just be sure if you're using a mobility controller that you have the proper discovery method in place (DHCP Option 43, DNS (aruba-master.yourdomain.com), or ADP if it's in the same subnet).
  • 5.  RE: Need AP's to obtain IP address from DHCP Server
    Posted Jan 17, 2015 03:40 PM
    Thanks.  ADP is on by default, right?
  • 6.  RE: Need AP's to obtain IP address from DHCP Server
    Posted Jan 17, 2015 07:58 PM
    Correct.
