Need for firmware update?
  • 1.  Need for firmware update?
    Posted Jun 21, 2017 09:50 AM
    Hello all,
    When do you decide a firmware update for your IAP's are necessary?  We're currently on version  6.4.4.4-4.2.3.2 with just over 300 AP's and everything is working great. We don't have a need for any new options and from what I can tell at www.arubanetworks.com/support-services/security-bulletins/ there's no security reason we would need an update. Just curious how others go about deciding if when they would update.
    Thanks for the space!
  • 2.  RE: Need for firmware update?
    Posted Jun 28, 2017 01:53 PM
    You are doing it right.
    You should only update the firmware to fix a bug, to patch a security issue, or to get a new feature that is important to you.
