last person joined: 11 hours ago
need help?
  • 1.  need help?
    Posted Jun 14, 2018 04:25 AM
    I upgraded my AirWave server from 8.0.7 to 8.0.10 and it looks like after the upgrade a new template was created under each of my AP groups.  The name of the new template is Aruba Instant Thin AP (Any Model) - 6.3.1.8-4.0.0.7_44641.  This is the contents of the new template:
    per-ap-settings %lan_mac%
    hostname %hostname%
    ip-address %ip_address% %netmask% %gateway% %dns_svr% %domain_name%
    swarm-mode %swarm_mode%
    uplink-vlan %vlan%
    wifi0-mode %wifi0_role%
    %if wifi1_role%
    wifi1-mode %wifi1_role%
    %endif%
    %if dot11g_disable%
    dot11g-radio-disable
    %endif%
    %if has_dot11g%
    g-channel %dot11g_channel% %dot11g_xmit_power%
    g-external-antenna %dot11g_antenna_gain%
    %endif%
    %if dot11a_disable%
    dot11a-radio-disable
    %endif%
    %if has_dot11a%
    a-channel %dot11a_channel% %dot11a_xmit_power%
    a-external-antenna %dot11a_antenna_gain%
    %endif%
    %if enet0_bridging%
    enet0-bridging
    %endif%
    %if preferred_master%
    iap-master
    %endif%
    %if zone_name%
    zonename %zone_name%
    %endif%
    %if usb_port_disable%
    usb-port-disable
    %endif%
    %if modem_pin%
    pin-enable %modem_pin%
    %endif%
    What is the purpose of this new template and do I need to keep it?
