I've retried to install the iMC with my remote mysql.
I confirm that the installer has a problem, you can find my log here :
2013-07-19 20:55:37 [INFO ] [main] [com.h3c.imc.deploy.Util::getOracleHome(503)] Find ORACLE_HOME=/opt/oracle/product/11.2.0/client_1
2013-07-19 20:55:37 [INFO ] [Thread-2] [com.h3c.imc.deploy.dma.AgentMessageHandler$1::run(849)] Agent start connect to server
2013-07-19 20:55:47 [INFO ] [Thread-2] [com.h3c.imc.deploy.dma.AgentMessageHandler$1::run(881)] Agent connection started
2013-07-19 20:55:47 [INFO ] [Thread-2] [com.h3c.imc.deploy.dma.AgentMessageHandler::connectStateChanged(1013)] Agent-Server connect state changed: Connected
2013-07-19 20:55:47 [INFO ] [Thread-2] [com.h3c.imc.deploy.dma.AgentMessageHandler$1::run(904)] Create Agent MQ connection completed
2013-07-19 20:55:57 [INFO ] [Database Checking Thread] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(157)] Start loading server-addr.xml configuration file
2013-07-19 20:55:57 [WARN ] [Database Checking Thread] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(162)] Config file is not exist - /opt/iMC/common/conf/server-addr.xml
2013-07-19 20:55:57 [INFO ] [main] [com.h3c.imc.deploy.dma.DeployManager::loadComponentDeployInfo(734)] Component deploy state changed
2013-07-19 20:55:58 [INFO ] [ActiveMQ Session Task] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(157)] Start loading server-addr.xml configuration file
2013-07-19 20:55:58 [WARN ] [ActiveMQ Session Task] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(162)] Config file is not exist - /opt/iMC/common/conf/server-addr.xml
2013-07-19 20:55:58 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.ComponentDeployInfo::isComponentsConformable(594)] Components conformable check failed: no component deployed
2013-07-19 20:55:58 [INFO ] [ActiveMQ Session Task] [com.h3c.imc.deploy.dma.AgentMessageHandler::masterConnectStateChanged(1038)] Receive master state change message: Connected
2013-07-19 20:56:02 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.DeployWizard$WizardData::parseTaskProperties(434)] Deploy component "iMC-PLAT" for the first time: true
2013-07-19 20:56:03 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.WelcomePanelDescriptor::aboutToDisplayPanel(95)] data.isNeedSelectDatabase() is : true
2013-07-19 20:56:03 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.WelcomePanelDescriptor::aboutToDisplayPanel(96)] data.isNeedInputWebServerPort() is : true
2013-07-19 20:56:03 [INFO ] [main] [com.h3c.imc.deploy.dma.wizard.WelcomePanelDescriptor::aboutToDisplayPanel(97)] data.isNeedShowCustomPanels() is : false
2013-07-19 20:56:05 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.ComponentDeployInfo::isComponentsConformable(499)] Components conformable check failed: invalid state - deploying
2013-07-19 20:56:05 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(269)] Start deploy component: iMC-PLAT [iMC PLAT 5.2 (E0401)]
2013-07-19 20:56:05 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(281)] Replacement Variables: {${COUNTRY}=US, ${DATABASE_ADDRESS}=192.168.3.38, ${DATABASE_ADMIN_PASSWORD_ESCAPE}={PROTECTED}, ${DATABASE_ADMIN_PASSWORD}={PROTECTED}, ${DATABASE_ADMIN_USERNAME}=iMC_mysql, ${DATABASE_PORT}=3306, ${DATABASE_TYPE}=MySQL, ${DEPLOY_IP}=127.0.0.1, ${HTTPS_PORT}=443, ${HTTP_PORT}=80, ${INSTALL_DESTINATION_DIR}=/opt/iMC, ${LANGUAGE_U}=C, ${LANGUAGE}=en, ${LOCAL_IP_0}=192.168.14.2, ${LOCAL_IP_1}=fe80:0:0:0:250:56ff:feac:2d52%2, ${LOCAL_IP_COUNT}=2, ${MASTER_IP}=localhost, ${SERVER_TYPE}=Master, ${iMC-PLAT['DEPLOY_IP']}=127.0.0.1}
2013-07-19 20:56:05 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - server_linux.zip...)...
2013-07-19 20:56:07 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - l2topo_server_linux.zip...)...
2013-07-19 20:56:07 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - client.zip...)...
2013-07-19 20:57:14 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - imc_dnd_sdk.zip...)...
2013-07-19 20:57:15 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - client_topoplat.zip...)...
2013-07-19 20:57:33 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - client_usertopo.zip...)...
2013-07-19 20:57:33 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - client_webdm_mibbrowser.zip...)...
2013-07-19 20:57:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - client_gencfg.zip...)...
2013-07-19 20:57:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - imcdm_topopanel_sdk_daily.zip...)...
2013-07-19 20:57:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - 3rd_license_plat.zip...)...
2013-07-19 20:57:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.UnzipFileTask(Unzipping file - client_iccconf.zip...)...
2013-07-19 20:58:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(157)] Start loading server-addr.xml configuration file
2013-07-19 20:58:34 [WARN ] [Thread-14] [com.h3c.imc.deploy.dma.IPConfigFileManager::readAllConfigs(162)] Config file is not exist - /opt/iMC/common/conf/server-addr.xml
2013-07-19 20:58:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(341)] Executing com.h3c.imc.deploy.tasks.BuildDatabaseTask(Building database - server/script_mysql.hz...)...
2013-07-19 20:58:34 [ERROR] [SwingWorker-pool-1-thread-4] [com.h3c.imc.deploy.tasks.BuildDatabaseTask$DatabaseBuilderWorker::doInBackground(902)] Execute database script error! return value: 1. For details, see log file: /etc/iMC-Reserved/log/dbresult_201307192058340.log
2013-07-19 20:58:34 [ERROR] [Thread-14] [com.h3c.imc.deploy.dma.wizard.DeployingPanelDescriptor$WorkingThread::run(346)] Task execute failed
2013-07-19 20:58:34 [INFO ] [Thread-14] [com.h3c.imc.deploy.dma.IPConfigFileManager::saveAllConfigs(342)] Save server address config OK
2013-07-19 20:58:35 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.ComponentDeployInfo::isComponentsConformable(594)] Components conformable check failed: no component deployed
And when i go into the file /etc/iMC-Reserved/log/dbresult_201307192058340.log
i see :
Begin to create config_db database...
ERROR 1044 (42000) at line 2: Access denied for user 'iMC_mysql'@'192.168.14.2' to database 'config_db'
The install of imcnetresdm finished unsuccessfully, please contact your local IMC support centre.
Why this **bleep**ing db script is going to try to install on the local server ???
If HP has some answer for that, i take....
