Need help new to Aruba and have no details for the system !!
  • 1.  Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:41 AM
    Hi Guys and girls.
    After a bit of help just taken on a new client as the old IT company has gone awol and its taken a couple of days just to get to where we are now. I have access to the servers now the NAS, CCTV etc and now the last piece of the jigsaw in is the AP's. Got a sonic wall in place to which i have managed to access and can see thats dishing out DHCP on two ranges how ever doing an IP scan on both ranges i cant see any AP's or the controller. The controller is a ARCN0104 which i believe is a cloud based controller. So if the client has no details the old IT compnay are no more and uncontactable how would i gain access to it ?
    Any help is greatly appriciated :)
    Many Thanks
    Rob
  • 2.  RE: Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:42 AM
    Do you have the ip address of the controller?
  • 3.  RE: Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:44 AM
    Hi there, nope can see it on either range using angry ip scanner can see nothing !!
  • 4.  RE: Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:50 AM
    i can see two devices labelled as
    Hostname:    ACA81112.ipt.aol.com
    would that be it ?
  • 5.  RE: Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:53 AM
    Hopefully you have a Cisco console cable and com port on your PC (+fysical access to the controller)?
    Put it in the console port on the controller and use following credentials user: password
    password: forgetme!
    Go into enable mode by typing "enable"
    Enable password = enable
    Type "configure terminal"
    Reset the admin password
    "mgmt-user admin root"
    > choose a new password
    Log out via exit
    Now log in via admin/ new password
    enable
    show ip interface brief
    Now you should have the ip adress and should be able to access the GUI with your credentials.
  • 6.  RE: Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:56 AM
    Awsome :) Ill try that tomorrow dont have my serial cable on me so will let you know tomorow how it goes thank you so much
    Do i need to set the baud rate on the com port or any specific setting ?
  • 7.  RE: Need help new to Aruba and have no details for the system !!
    Posted Aug 29, 2017 10:58 AM
    9600
    (use standard putty settings)
  • 8.  RE: Need help new to Aruba and have no details for the system !!
    Posted Sep 10, 2017 12:46 AM
    Hi Guys,
    Just to let you know all is working now and we have reset the password thanks for you help much appriciated and i am sure ill be asking more questions.
    Thanks again
    Rob
