Aruba Central
Need help replacing a Procurve 3800-24G with a Aruba 6300M
  • 1.  Need help replacing a Procurve 3800-24G with a Aruba 6300M
    Posted 12 days ago
    I have a Procurve 3800-24G switch that is randomly locking up and requiring a reboot every 2-3 weeks or so. After consulting with my hardware provider I was told that the Aruba 6300M would be a replacement for the failing one... unfortunately, nobody told me that the CLI language was completely different and I'm struggling to understand this one, as I've never worked with it, and rushing trying to have a replacement ready in case of permanent failure.
    Can anyone help me with this?  I've pasted the current procurve switch config below... I (think) I need some clarification mostly on the "trunk" commands and the set up of VLANS with tagged and untagged ports, but if anything else sticks out as working fundamentally different, let me know.
    Running configuration:
    ; J9585A Configuration Editor; Created on release #KA.15.16.0008
    ; Ver #06:7c.fd.ff.ff.3f.ef:57
    hostname "Main-3800-24G"
    module 1 type j9585x
    class ipv4 "Windward"
         5 match ip 10.0.70.0 255.255.255.0 0.0.0.0 255.255.255.255
       exit
    policy pbr "Alpharetta"
         10 class ipv4 "Windward"
          action ip next-hop 10.128.20.2
          exit
       exit
    trunk 1-2 trk1 trunk
    trunk 3-4 trk2 trunk
    ip route 0.0.0.0 0.0.0.0 10.128.20.2
    ip route 10.0.10.0 255.255.255.0 10.128.20.2
    ip route 10.1.1.0 255.255.255.0 10.128.20.2
    ip route 10.128.10.0 255.255.255.0 10.128.20.2
    ip route 10.128.110.0 255.255.255.0 10.128.20.2
    ip route 192.168.215.0 255.255.255.0 10.128.20.2
    ip routing
    snmp-server community "public" unrestricted
    oobm
       ip address dhcp-bootp
       exit
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 5-8,10,12-19,21-24,Trk1-Trk2
       untagged 9,11,20,25-26
       exit
    vlan 2
       name "VLAN2"
       no ip address
       exit
    vlan 20
       name "Transit"
       untagged 5,10,22
       tagged Trk1-Trk2
       ip address 10.128.20.9 255.255.255.0
       exit
    vlan 50
       name "server380"
       untagged 6-7,24
       tagged 12-13,Trk1-Trk2
       ip address 10.128.50.9 255.255.255.0
       dhcp-server
       exit
    vlan 70
       name "WiFiCL"
       tagged 19-24,Trk1-Trk2
       ip address 10.0.70.9 255.255.255.0
       service-policy "Alpharetta" in
       dhcp-server
       exit
    vlan 75
       name "VoIP"
       untagged 13-18
       tagged Trk1-Trk2
       ip address 10.0.75.9 255.255.255.0
       ip helper-address 10.0.80.40
       exit
    vlan 80
       name "WiFiMGMT"
       untagged 8,21,23
       tagged 19-20,Trk1-Trk2
       ip address 10.0.80.9 255.255.255.0
       dhcp-server
       exit
    vlan 99
       name "amazonsecure"
       tagged Trk1-Trk2
       ip address 10.0.99.9 255.255.255.0
       dhcp-server
       exit
    vlan 560
       name "VLAN560"
       no ip address
       exit
    spanning-tree
    spanning-tree Trk1 priority 4
    spanning-tree Trk2 priority 4
    spanning-tree priority 0
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    dhcp-server pool "Transit"
       authoritative
       default-router "10.128.20.9"
       dns-server "10.1.1.22"
       lease 02:00:00
       range 10.128.20.100 10.128.20.200
       exit
    dhcp-server pool "server380"
       authoritative
       default-router "10.128.50.9"
       lease 02:00:00
       network 10.128.50.0 255.255.255.0
       range 10.128.50.100 10.128.50.200
       exit
    dhcp-server pool "VoIP"
       authoritative
       default-router "10.0.75.9"
       lease 02:00:00
       network 10.0.75.0 255.255.255.0
       range 10.0.75.100 10.0.75.200
       exit
    dhcp-server pool "WifiCL"
       authoritative
       default-router "10.0.70.9"
       lease 02:00:00
       network 10.0.70.0 255.255.255.0
       range 10.0.70.100 10.0.70.200
       exit
    dhcp-server pool "amazonsecure"
       authoritative
       default-router "10.0.99.9"
       lease 02:00:00
       network 10.0.99.0 255.255.255.0
       range 10.0.99.100 10.0.99.200
       exit
    dhcp-server pool "WIFImgmt"
       authoritative
       default-router "10.0.80.9"
       lease 02:00:00
       network 10.0.80.0 255.255.255.0
       range 10.0.80.100 10.0.80.254
       exit
    dhcp-server enable
    password manager
  • 2.  RE: Need help replacing a Procurve 3800-24G with a Aruba 6300M
    Posted 12 days ago
    There are useful documents that put the CLI commands for Provision/ArubaOS-Switch and AOS-CX next to eachother. If you scroll down in this page, there are a few versions (version 5 is latest at the moment).
    Quickest to get this done, if you don't want to read through the full guide, is to ask your Aruba reseller as they should have experience with this.
