Wired Intelligent Edge
Need help to setup a working nat on my MSR954
  • 1.  Need help to setup a working nat on my MSR954
    Posted May 28, 2021 09:57 AM
    The situation is as follows:
    Provider edge: IP 10.1.0.73/30 on trunk vlan 200 with route pointing the 214.211.169.52/30 to the address 10.1.0.74/30.
    My edge: IP 10.1.0.74/30 on trunk vlan 200 (vlan in interface 0/0)
    To here everything is good, my side can ping the provider.
    I created a default route on my router pointing to 10.1.0.73.
    I put the IP 10.1.0.74/32 on interface 0/4.1 and if I use "ping -a 10.1.0.74 any_public_ip" I'm able to ping the public IP.
    I have then created a private IP address 192.168.0.1/24 on 0/4 on route mode (not trunk).
    How can I NAT all the addresses on 192.168.0.1/24 to the 10.1.0.74/32 in order to access the internet on those workstations?
    Anyone can help? Thanks in advance...
    Mateus Côrtes
  • 2.  RE: Need help to setup a working nat on my MSR954
    Posted May 30, 2021 10:58 AM
    A  few possible few ways to do this.
    I would  encourage you to read the info IP services guide for the product here https://support.hpe.com/hpesc/public/docDisplay?docId=c05370682 to work to your setup.
    something like below may be possible
    int gig X/y
    port link-mode route
    my IP A.B.C..D  & Mask
    nat outbound 2000 address-group 1
    acl basic 2000
     rule 5 permit source  W.X.Y.Z 0.0.0.255 (Class C)
     rule 10 deny
    Kamal Takodra
  • 3.  RE: Need help to setup a working nat on my MSR954
    Posted Oct 02, 2021 08:35 PM
    I should put the nat outbound on the interface with public IP or on the interface with private IP?
    Also, the public IP is on a LoopBack interface, I can't set the port-mod of a LoopBack interface.
    Could you please give me a more specific configuration example?
    Mateus Côrtes
