Need help with Aruba 620 running Version 5.0.4.3
  • 1.  Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 13, 2014 05:06 PM
    So, I have a client that had a power outage last night, and the Aruba controller didn't restore successfully.
    Had to power cycle it, everything seemed to come back up, but now the customer is stating that whenever they try to use a web browser, the get the following message "Web Authentication is disabled. Please contact the Admin for assistance".
    The browser has the red slash through the "https" and is trying to prompt them to log via GIU.
    This should not be Captive based for the internal Corp users.
    Any help would be greatly appreciated.
  • 2.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 13, 2014 06:01 PM
    So are the clients authenticating correctly? They just cant browse?
    Do you have a backup file?
    Might even check the audit trail to see if something got accidently changed
  • 3.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:07 AM
    Yes, from my understanding they can connect and authenticate. They just can't browse.
  • 4.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 13, 2014 08:05 PM
    check the licences.  It sounds like the PEF licence is missing and they may be being put into some sort of logon role and hitting the captiveportal acl.
  • 5.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:11 AM
    Not being very savy with the Arube, and wireless, where would I be checking on this?
    If it helps, I have attached the current config. And the past config.
    Attachment(s)
    txt
    Aruba Config 0702.txt   18 KB 1 version
  • 6.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:12 AM
    Current COnfig
  • 7.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:14 AM
    not attached
  • 8.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:16 AM
    For some reason it can't attach the current config
  • 9.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:18 AM
    can you do a 'show license' on the controller?
    Couple more that would be useful
    show profile-errors
    show user-table  --> to see what role the users are in
  • 10.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:42 AM
    Show License results
    (Equity620) #show license
    License Table
    Key                                               Installed   Expires  Flags  Service Type
    NFP5OqR0-sXKaFEfv-lPUdRyGo-ENGSwwkZ-i2WHvnUr-EfY  2011-12-18  Never     E     Next Generation Policy Enforcement Firewall Module: 4
                                                      09:56:16
    bGnbfn8J-yd4pzg/o-Y96JYnOq-5+3A0Maj-DYnv/Kwx-UtU  2011-12-18  Never     E     Wireless Intrusion Protection Module: 4
                                                      09:56:38
    vYw7pjZu-YGmHAtUr-mjIstBZT-QKe8i8aM-tVAYY+z8-QOE  2011-12-23  Never     E     Access Points: 8
                                                      03:58:46
    hLb0bg2U-5NN+LtsX-UGALa0W7-uAIxuy1w-dZ2kibTi-+As  2011-12-23  Never     E     Next Generation Policy Enforcement Firewall Module: 4
                                                      03:59:59
    cGiIzSPj-hUmANNZe-uk16FqON-MIq1/XIj-nBtCO7Ga-Pmg  2011-12-23  Never     E     Wireless Intrusion Protection Module: 4
                                                      04:00:33
    License Entries: 5
  • 11.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:45 AM
    (Equity620) # show profile-errors
    Invalid Profiles
    Profile  Error
    (Equity620) #show user-table
    Users
        IP                MAC            Name     Role           Age(d:h:m)  Auth  VPN link  AP name         Roaming   Essid/Bssid/Phy                    Profile        Forward mode
    10.0.1.128       bc:77:37:c8:47:86            logon          00:00:01                    Equity_65_2_N   Wireless  Equity_Tenant/00:0b:86:5b:a4:e2/g  default-dot1x  tunnel
    10.0.5.130       00:25:9c:a3:5d:2a            authenticated  00:04:24                    Equity_65_1_SW  Wireless  Equity_Tenant/00:0b:86:5b:a3:42/g  default-dot1x  tunnel
    10.0.1.149       0c:84:dc:ad:8c:c2            logon          00:00:01                    Equity_65_2_N   Wireless  Equity_Tenant/00:0b:86:5b:a4:e2/g  default-dot1x  tunnel
    10.0.1.223       d4:85:64:34:c6:01            logon          00:00:05                    Equity_65_2_N   Wireless  Equity_Tenant/00:0b:86:5b:a4:e2/g  default-dot1x  tunnel
    10.0.1.228       08:86:3b:03:45:bb            logon          00:00:01                    Equity_65_2_N   Wireless  Equity_Tenant/00:0b:86:5b:a4:e2/g  default-dot1x  tunnel
    169.254.201.151  00:25:9c:a3:5d:2a            authenticated  00:04:23                    Equity_65_1_SW  Wireless  Equity_Tenant/00:0b:86:5b:a3:42/g  default-dot1x  tunnel
    169.254.42.134   2c:76:8a:b7:2a:86            authenticated  00:09:11                    Equity_65_2_S   Wireless  Equity_Tenant/00:1a:1e:ba:bc:e2/g  default-dot1x  tunnel
    User Entries: 7/7
  • 12.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 08:59 AM
    First glance.
    Your vap profile has a aaa-profile of 'Captive-portal'
    wlan virtual-ap "Corp_Tenant"
       aaa-profile "Captive-portal"
    And there is no dot1x profile assigned to that as well and the users are ending up in that logon role.
    Change the aaa profile to be  "Corp-dot1x".  I assume that is the one they should be using.
  • 13.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 09:16 AM
    Here is the current config.
    aaa authentication mac "default"
    aaa authentication dot1x "Copr_peap"
    --More-- (q) quit (u) pageup (/) search (n) repeat
    aaa authentication dot1x "Corp_peap"
       max-authentication-failures 5
       machine-authentication machine-default-role "Corp_Internal"
       machine-authentication user-default-role "Corp_Internal"
       reauthentication
       termination enable
       termination eap-type eap-peap
       termination inner-eap-type eap-mschapv2
    aaa authentication dot1x "default"
    aaa authentication dot1x "default-psk"
       termination enable
    aaa server-group "default"
     auth-server Internal
     set role condition role value-of
    aaa authentication via connection-profile "default"
    aaa authentication via web-auth "default"
    aaa authentication via global-config
    aaa profile "Captive-portal"
       initial-role "Captive_User"
       no wired-to-wireless-roam
    aaa profile "Corp-dot1x"
       initial-role "authenticated"
       mac-default-role "logon"
       authentication-dot1x "Corp_peap"
       dot1x-default-role "authenticated"
       dot1x-server-group "internal"
    aaa profile "Corp-psk"
    aaa profile "default"
    aaa profile "default-dot1x"
    aaa authentication captive-portal "default"
    aaa authentication captive-portal "Equity_Guest"
       default-role "Captive_User"
       login-page "/upload/custom/Equity_Guest/Equity_Guest.html"
       show-acceptable-use-policy
    aaa authentication wispr "default"
    aaa authentication vpn "default"
    aaa authentication vpn "default-rap"
    aaa authentication mgmt
    aaa authentication stateful-ntlm "default"
    aaa authentication stateful-kerberos "default"
    aaa authentication stateful-dot1x
    aaa authentication via auth-profile "default"
  • 14.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 09:23 AM
       aaa-profile "default-dot1x"
       ssid-profile "Corp_Tenant"
       dos-prevention
       band-steering
    That is the current setting.
    Can't understand why I am not able to attach this notepad with the current config.
  • 15.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 09:47 AM
    I can't see why it is not working from that.  Couple of things though.
    You have termination enabled.  Check the clock on the controller as it maybe have been reset to some wonky time.
    The only thing I can suggest at this stage is the following.
    aaa-profile default
    write memory
    write memory
    Failing that, you should restore a previous working flashbackup.
  • 16.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 10:07 AM
    Okay, so I made the change and reloaded. I will see if this resolves the issue.
    Any way of getting you the current config, as the one that I was able to post here is an old, but working config.
  • 17.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 14, 2014 01:39 PM
    So, now I am gettign reports that the SSID can connect, but it DHCP is not happening.
  • 18.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 15, 2014 08:02 AM
    Still in a real bind on this. Any help would be great.
  • 19.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 15, 2014 08:06 AM
    do you have a flashbackup from when it was working before?
  • 20.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 15, 2014 08:09 AM
    I don't, unfortunatly. The only backup I have is in the form of that original Notepad I provided. I know that config was operational.
  • 21.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 15, 2014 09:12 AM
    Not really have a lot of experience with the Aruba controllers, is it common practice to blow out the config and push a copy & paste for the config?
  • 22.  RE: Need help with Aruba 620 running Version 5.0.4.3
    Posted Aug 15, 2014 09:29 AM
    Typically, no.  It is possible if you have no choice, but fraught with difficulties and will give some (or lots) of errors that need to be manually fixed after.  It won't also restore the local-userdb and other things like that.
    What role are your users in at the moment?  Can you get details about a specific user from 'show user mac <mac>'.
    Have you engaged with Aruba TAC for assistance on this as well?
